espefuse.py Alternative
Aidin77
Postby Aidin77 » Sun Feb 07, 2021 5:37 pm
According to https://docs.espressif.com/projects/esp ... ments.html
components/esptool_py/esptool/espefuse.py set_flash_voltage 3.3V
This command will burn the XPD_SDIO_TIEH, XPD_SDIO_FORCE, and XPD_SDIO_REG eFuses.
could I replacing the above command with this program ?
#include <stdio.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_spi_flash.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
#include "driver/periph_ctrl.h"
#include "soc/rtc_cntl_reg.h"
#include "rom/efuse.h"
#include "soc/efuse_reg.h"
#include "soc/soc.h"
#include "esp_efuse.h"
#include "esp_log.h"
static const char *TAG = "efuse";
void setup(){
  bool burned = false;
  printf("\nWarning! Once the eFuses are burned you cannot revert back!");
  vTaskDelay(5000 / portTICK_PERIOD_MS);
  //burning BLOCK3 bit0
  if (!!(REG_READ(EFUSE_BLK0_RDATA4_REG) & EFUSE_RD_SDIO_TIEH) == 0) { //check if eFuse was previously burned (if not burned eFuse == 0)
        ESP_EARLY_LOGI(TAG, "\nBurning EFUSE_BLK0_WDATA4_RE fuse EFUSE_RD_SDIO_TIEH to 1");
        esp_efuse_reset();
        REG_WRITE(EFUSE_BLK0_RDATA4_REG, EFUSE_RD_SDIO_TIEH);
    esp_efuse_burn_new_values();
    burned = true;
    }else{
    printf("\nSDIO_TIEH already burned");
  //burning SDIO_FORCE
  if (!!(REG_READ(EFUSE_BLK0_RDATA4_REG) & EFUSE_RD_SDIO_FORCE) == 0) {
        ESP_EARLY_LOGI(TAG, "\nBurning EFUSE_BLK0_WDATA4_RE fuse EFUSE_RD_SDIO_FORCE to 1");
        esp_efuse_reset();
        REG_WRITE(EFUSE_BLK0_WDATA4_REG, EFUSE_RD_SDIO_FORCE);
    burned = true;
    }else{
    printf("\nSDIO_FORCE already burned");
  //burning SDIO_REG
  if (!!(REG_READ(EFUSE_BLK0_RDATA4_REG) & EFUSE_RD_XPD_SDIO_REG) == 0) {
        ESP_EARLY_LOGI(TAG, "\nBurning EFUSE_BLK0_WDATA4_RE fuse EFUSE_RD_XPD_SDIO_REG to 1");
        esp_efuse_reset();
        REG_WRITE(EFUSE_BLK0_WDATA4_REG, EFUSE_RD_XPD_SDIO_REG);
    burned = true;
    }else{
    printf("\nSDIO_REG already burned");
  if(burned)
    printf("\nFuses burned!");
  else
    printf("\nFuses already burned!");
  for (int i = 5; i >= 0; i--) {
        printf("\nRestarting in %d seconds...\n", i);
    printf("\nRestarting now.\n");
    fflush(stdout);
    esp_restart();
Users browsing this forum: No registered users and 119 guests
