ESP32-PICO-KIT SPIFFS problems?
brianpdx
Postby brianpdx » Fri Jan 29, 2021 6:26 am
I've created a 192KB SPIFFS partition on an ESP32-PICO-KIT. After formatting,
esp_spiffs_info()
says the filesystem size is 173,441 bytes. I then create 74 roughly 2KB files and the filesystem shows the used space as 154,365 bytes, or 89% full.
At this point attempting to create more files fails,
open(path, O_APPEND|O_CREAT|O_WRONLY)
returns
ENOENT
I don't understand why this is happening. There is approximately 19KB free so it should be able to create a new file.
Are the SPIFFS filesystem limits published somewhere? Is there a limit to the number of files the SPIFFS filesystem can contain?
Does anyone have other ideas as to what might be the cause?
Thank you,
Brian
ESP_Minatel
Re: ESP32-PICO-KIT SPIFFS problems?
Postby ESP_Minatel » Fri Jan 29, 2021 2:52 pm
Hi Brian,
Take a look at this thread viewtopic.php?t=12166
Users browsing this forum: No registered users and 99 guests
