problems with interrupts
attila666
Postby attila666 » Thu Jan 21, 2021 8:19 am
Hello everyone, sorry but I have a problem and I have not been able to get out of it for months, I am trying to manage the lights, and I would like to control 8 relays with 8 buttons, the system works but, using the interrupts, I cannot stabilize the program, so if I repeatedly press the buttons the Sketch stops, maybe the problem is my wrong way to use IRAM, the configuration is the following ESP32, mcp23017 and under the Sketch, could someone tell me what am I wrong? thank you very much p.s. sorry my english, i use google translator
#include <Wire.h>
#include "Adafruit_MCP23017.h"
#include <SPI.h>
byte IntPin = 23; // collegare entrata interrupt mcp A------------------------
volatile boolean awakenByInterrupt = false;
static uint16_t ledState = 0;
boolean led_state[8];
byte pinLed[] = {7, 6, 5, 4, 3, 2, 1, 0};
byte buttons[] = {8, 9, 10, 11, 12, 13, 14, 15};
int i ;
int test;
Adafruit_MCP23017 mcp;
  mcp.begin();
  pinMode(IntPin, INPUT);
  for (i = 0; i < (8); i++) {
    mcp.pinMode(buttons[i], INPUT);
    mcp.pinMode(pinLed[i], OUTPUT);
    mcp.digitalWrite(pinLed[i], LOW);
    led_state[i] = false;
    mcp.setupInterruptPin(buttons[i], RISING);
  mcp.readGPIOAB();
  mcp.setupInterrupts(true, false, LOW);
  attachInterrupt(digitalPinToInterrupt(IntPin), intCallBack, FALLING);
ICACHE_RAM_ATTR void intCallBack() {
  awakenByInterrupt = true;
void handleInterrupt() { // gestione pulsanti da interrupt************************************************************************************
  noInterrupts();
  uint8_t pin = mcp.getLastInterruptPin();
  //uint8_t val = mcp.getLastInterruptPinValue();
  led_state[pin - 8] = ! led_state[pin - 8];
  if (led_state[pin - 8]) mcp.digitalWrite(pinLed[pin - 8], HIGH);
  else mcp.digitalWrite(pinLed[pin - 8], LOW);
  delay(35);
  //mcp.readGPIOAB();
  while ( !(!mcp.digitalRead(buttons[0]) && ! mcp.digitalRead(buttons[1]) &&  !mcp.digitalRead(buttons[2]) && !mcp.digitalRead(buttons[3]) && !mcp.digitalRead(buttons[4]) && !mcp.digitalRead(buttons[5]) && !mcp.digitalRead(buttons[6]) && !mcp.digitalRead(buttons[7])));
  interrupts();
  if (awakenByInterrupt) handleInterrupt();
attila666
Re: problems with interrupts
Postby attila666 » Sat Jan 23, 2021 5:23 pm
Now I remember why I had left this forum, 94 visits and not even a reply, even if it was "forget it", p.s. is it because I don't speak english ??
ESP_Sprite
Postby ESP_Sprite » Sun Jan 24, 2021 3:57 am
Possibly, your use of Google Translate certainly does not help. Furthermore, I imagine 94 people just like me went over your code and went 'dunno, looks good to me, hope he finds his problem'.
lbernstone
Postby lbernstone » Sun Jan 24, 2021 3:35 pm
Put a delay(150); in your loop. This will act to debounce your button interrupt (I assume you are not The Flash), as well as prevent the tight looping that can starve your cpu.
Michalpu
Postby Michalpu » Mon Jan 25, 2021 7:49 pm
I had used while in while to check if button is pressed this prevent from sending pressed singal all the time
Content creator at https://911electronic.com
attila666
Postby attila666 » Thu Jan 28, 2021 11:26 pm
thanks for the answers, I didn't check before because I didn't think you answered :) anyway for info I have a hardware debounce and that I checked with an oscilloscope and that works correctly by eliminating the bounces, in the following code I have centered the problem, in the attached photo l last message of the serial is when the ESP32 is blocked. - I don't want to insert delays if I can solve it from code
https://www.dropbox.com/s/680o5ag84uex6 ... e.JPG?dl=0
#include <Wire.h>
#include <SPI.h>
boolean ledState = 0;
boolean Ccheck = 1;
int i ;
//ICACHE_RAM_ATTR
void IRAM_ATTR intCallBack() {
  Serial.println("puntoIRAM");
  if (Ccheck == 1) {
    Serial.println("punto4");
  mcp.begin();
    mcp.pullUp(buttons[i], HIGH); //------------------- da valutare
  mcp.readGPIOAB();
  Ccheck = 0;
  Serial.println("punto5");
  while (mcp.digitalRead(buttons[0]));
  Serial.println("puntoW1");
  while (mcp.digitalRead(buttons[1]));
  while (mcp.digitalRead(buttons[2]));
  while (mcp.digitalRead(buttons[3]));
  while (mcp.digitalRead(buttons[4]));
  while (mcp.digitalRead(buttons[5]));
  while (mcp.digitalRead(buttons[6]));
  while (mcp.digitalRead(buttons[7]));
  Serial.println("punto6");
  mcp.readGPIOAB();
  Serial.println("punto7");
  Ccheck = 1;
  Serial.print("awakenByInterrupt > "); Serial.println(awakenByInterrupt);
  Serial.println("------------------");
  Serial.print("buttons 1 > "); Serial.println(mcp.digitalRead(buttons[0]));
  Serial.print("buttons 2 > "); Serial.println(mcp.digitalRead(buttons[1]));
  Serial.print("buttons 3 > "); Serial.println(mcp.digitalRead(buttons[2]));
  Serial.print("buttons 4 > "); Serial.println(mcp.digitalRead(buttons[3]));
  Serial.print("buttons 5 > "); Serial.println(mcp.digitalRead(buttons[4]));
  Serial.print("buttons 6 > "); Serial.println(mcp.digitalRead(buttons[5]));
  Serial.print("buttons 7 > "); Serial.println(mcp.digitalRead(buttons[6]));
  Serial.print("buttons 8 > "); Serial.println(mcp.digitalRead(buttons[7]));
  Serial.print("IntPin > "); Serial.println(digitalRead(IntPin));
  Serial.print("val > "); Serial.println(digitalRead(val));
attila666
Postby attila666 » Thu Jan 28, 2021 11:33 pm
@ lbernstone
is correct what you say, even so without delay if you press not fast, it works, but I would like to understand how to optimize it :D
attila666
Postby attila666 » Thu Jan 28, 2021 11:34 pm
@Michalpu
I'm sorry I did not understand
Users browsing this forum: No registered users and 98 guests
