Symbol not found in eclipse
I have installed the plugin in Eclipse for embedded C/C++ developers. The project is building successfully with no errors or warning, but there are several problems of the type "Symbol XXX could not be resolved". sdkconfig.h has been included in the project. What is the solution to this?
- Screenshot from 2021-01-08 17-46-53.png (356.11 KiB) Viewed 2690 times
Re: Symbol not found in eclipse
See if this helps.
If you still see the issue, remove the build directory and re-build the project.
Project > C/C++ Index > Freshen All Files
Users browsing this forum: No registered users and 35 guests
