build and menuconfig errors ( CXX )
DutchOrange
Postby DutchOrange » Sat Jan 02, 2021 5:53 pm
So, I was trying to setup the ESP-MDF but when I tried "idf.py menuconfig" or "idf.py build" I get the error
It seems to only be a problem with the "Get-started" Example in the MDF and not any of the others (like blink) in the IDF.
 Tell CMake where to find the compiler by setting either the environment
  variable "CXX" or the CMake cache entry CMAKE_CXX_COMPILER to the full path
  to the compiler, or to the compiler name if it is in the PATH.
I found the CXX folder but what next ?, And Can I run this on a windows machine ?
Users browsing this forum: No registered users and 8 guests
