can someone explain what is the difference between esp aws iot component and original aws iot embedded c sdk?
esp aws iot component is based on original aws iot embedded c sdk but directory structure of aws iot embedded c in esp aws iot component is totally different than the directory structure of original aws iot embedded c sdk. I also cant find the same files. Can I use directly original aws iot embedded c sdk? Will i need to make lot of changes to use directly original aws iot embedded c sdk? Are all those changes done already inside esp aws iot component?
esp aws iot versus aws iot embedded c sdk
Users browsing this forum: ESP_Roland, Google [Bot] and 51 guests
