I want to modify some esp-idf components for a specific project and dont change the sdk's original component. The perfect way for me would be to :
- Build the project; The usefull esp-idf includes components are cloned in a new project's directory.
- Modifiy the cloned components as i want.
- Rebuild the project , not from the original components but from the modified ones from my cloned components.
I am a bit struggling with CMake. I found that we can list the components with idf_build_get_property(COMPONENTS). Is there a simple way or tool to do this ? Or a better solution ?
Thank you for your time,
Tibi
Copy components in new dir when building
Re: Copy components in new dir when building
Hi Tibi
Documentation pointer at https://docs.espressif.com/projects/esp ... -same-name can be helpful for you.
Idea here is to duplicate component within your project under `components` directory, and it shall take preference while building because of same name.
For example: if you duplicate `freertos` under `components` in example at https://github.com/espressif/esp-idf/tr ... em/console, then you can freely modify and example will use your copy.
Hope this helps.
Mahavir
Hope this helps.
Mahavir
Mahavir
https://github.com/mahavirj/
Users browsing this forum: Monskiller and 125 guests
