I am new to this forum, so I want to take the opportunity and say hello to everybody.
4 months ago I discovered arduino, and since then I've been playing a lot with it doing basic stuff like controlling leds, using it with various sensors, servos, etc. Recently, I came across esp32 which seems to be the newest and coolest kid in town and I'd like to start using it for a small home automation project I have in my mind. My first goal is to have a couple of esp32's spread around the house and use can bus for communication. I am an experienced programmer, but when it comes to electric circuits I am an absolute beginner. I stumbled upon one of the products from olimex (ESP32-EVB) which is build around esp32 wich includes a canbus circuit. The good part is that it's open source, the bad part is that I have some difficulties understanding their circuit - the areas that are highlighted with red from this screenshot http://storage8.static.itmages.com/i/17 ... 8099a3.png . I suspect that area 1 from the circuit is some sort of a logic converter, but I don't understand how can I put it on a breadboard. 2 is probably a jumper, which once mounted, adds 120R resistor to mark the end of the can bus line. I have no idea what 3 (PWR_FLAG) means. The schematic for the whole board can be found here https://www.olimex.com/Products/IoT/ESP ... _Rev_B.pdf
Any help will be appreciated.
Thank you.
can bus circuit
Re: can bus circuit
1. MCP2551 is 5v chip. Power supply choice is probably to give you (or them) the option to use a 3.3v chip. So if you are using MCP2551 then just ignore and connect to 5v. Level shift is done by 330/680 resistor divider.
2. Yes for bus termination
3. This is just notation for the software to tell it which connections are part of the power supply.
Re: can bus circuit
And PLEASE, if you are connecting to a vehicle, use a proper automotive transceiver instead of the MCP2551 piece of junk. TJA1042TK/3 would work fine and has the correct logic levels for the ESP32.
Re: can bus circuit
I am not interested in connecting the esp to my car, I just want to experiment a bit with can bus to see how suitable would it be for a small home automation project that I have in my mind. So far, the results are encouraging. Instead of MCP2551 I used SN65HVD230 (3.3 v logic). It simplified the circuit and it worked flawlessly across a 120m cable with 2 termination nodes. I used the can driver from here https://github.com/ThomasBarth/ESP32-CA ... onents/can
Re: can bus circuit
Hello tuflix,
Can you please post a schematic of your circuit and BOM?
Users browsing this forum: No registered users and 51 guests
