Hello, I have a problem with the implementation of the code that would support esp32 quadrature encoders. Anyone know how to do it on interrupts? I only need to read impulses. I have 1920 per revolution on these engines. The arduino waved very nicely. Anyone have any idea ?? There are some libraries on google, but I don't understand how to implement it.
It's arduino code, it worked great. Taken from the website https://wiki.dfrobot.com/Micro_DC_Motor ... U__FIT0450
As in the link, I have the same motors and encoders.
[Codebox]
//The sample code for driving one way motor encoder
const byte encoder0pinA = 2;//A pin -> the interrupt pin 0
const byte encoder0pinB = 3;//B pin -> the digital pin 3
byte encoder0PinALast;
int duration;//the number of the pulses
boolean Direction;//the rotation direction
void setup()
Serial.begin(57600);//Initialize the serial port
EncoderInit();//Initialize the module
void loop()
Serial.print("Pulse:");
Serial.println(duration);
duration = 0;
delay(100);
void EncoderInit()
Direction = true;//default -> Forward
pinMode(encoder0pinB,INPUT);
attachInterrupt(0, wheelSpeed, CHANGE);
void wheelSpeed()
int Lstate = digitalRead(encoder0pinA);
if((encoder0PinALast == LOW) && Lstate==HIGH)
int val = digitalRead(encoder0pinB);
if(val == LOW && Direction)
Direction = false; //Reverse
else if(val == HIGH && !Direction)
Direction = true; //Forward
encoder0PinALast = Lstate;
if(!Direction) duration++;
else duration--;
[/Codebox]
ESP32 encoder quadrature/rotary encoder
Users browsing this forum: No registered users and 48 guests
