Is it possible to force running the web page on the station connected to esp AP?
WiFi AP web page.
Re: WiFi AP web page.
This is what I would like to achive in 0:14
https://www.youtube.com/watch?v=PJUkRxL ... e=emb_logo
I was trying to use DNS server example from github but any of them doesn't force opening the captive page after connecting to AP.
Sure, just create/start the server on the IP of your interface. The server does not care if you are Wifi, Wired, Whatever. Just the IP.Is it possible to force running the web page on the station connected to esp AP?
So thinking ahead guess you just need to launch when you have an IP (& stop when loose etc). In which case you need to look at the event handlers.
I tested this https://github.com/cornelis-61/esp32_Captdns example, but it is not working such as I want.
DNS packets are sendings to server but, server don't force opening the captive page :/
I also put this code after wifi AP init
Results is still the same. :/
ip_addr_t dns_addr;
IP_ADDR4(&dns_addr, 192,168,1,2);
dns_setserver(0, &dns_addr);
dns_init();
xTaskCreate(&http_server, "http_server", 2048, NULL, 5, NULL);
Also trying to send HTTP/1.1 302 Found Location: 192.168.1.2\r\n
What I need to do to see 'sign to wifi network' popup on my smartphone?
I tested the Arduino example from:
https://github.com/espressif/arduino-es ... Portal.ino
and it is working perfectly.
How to start the DNS server in C, like in this arduino code?
Users browsing this forum: wxd2024 and 150 guests
