BT-BLE: Possible to change the uuid via ConfigManager
Stargazer
Postby Stargazer » Sat Nov 28, 2020 8:00 pm
Hi to all of this forum !
I use the ESP32 DevKit and want to build a garage opener with the ESP an a Shelly-Device.
So i want to switch the shelly via webhook and the posibillity of BLE.
For the configuration, i use the ConfigManager from Nick Wiersma:
https://github.com/nrwiersma/ConfigManager
On the HTML - Site on the ESP, i have a point to set the own UUID in 128bit.
This parameter will be stored on the ESP.
With the following part, i stored this uuid from the configManager to an array:
[Codebox]char* ibeacon1 = config.uuideins_name;[/Codebox]
The only thing i want is to transfer this ibeacon1 - char to the service UUID. Here is the code:
[Codebox]static BLEUUID serviceUUID("88bdf79f-59ec-4f47-bf82-39b957c5XXXX");[/Codebox]
Is ist possible to change it from an extern manager like the ConfigManager.
If i change it to : [Codebox]static BLEUUID serviceUUID(ibeacon1);[/Codebox] the UUID - number is missing.
I can control it with a [Codebox]Serial.println(serviceUUID.toString().c_str());[/Codebox]
I'am a little bit in trouble with the BLE - Libary's, i think... :?
Thanks a lot and best regards
André
Stargazer
Re: BT-BLE: Possible to change the uuid via ConfigManager
Postby Stargazer » Mon Nov 30, 2020 7:22 pm
the problem with the UUID is solved.
But, i want to use a second i-beacon - UUID for the filter.
In my case, i use the serviceUUID2 declaration of the BLEUUID.
char* ibeacon2 = config.uuidzwei_name;
         static BLEUUID serviceUUID2(ibeacon2);
The Filter looks like:
if (advertisedDevice.haveServiceUUID()&& advertisedDevice.isAdvertisingService(BLEUUID(serviceUUID2))&
             advertisedDevice.getRSSI() > rssibeacon)
Everything runs perfect. But if i send these UUID from nFC for mobile, he doesn't react.
Has anybody the same problem ?
BR
André
Users browsing this forum: No registered users and 44 guests
