I am currently trying to setup the ESP-IDF plugin for VS Code under Linux.
esptool.py is installed under /usr/bin and can be be invoked without problems either from the inbuilt VS Code terminal or my normal shell.
However, when I try to flash via the plugin command, VS Code tells me that esptool.py can't be found.
How can I fix this?
VS Code cannot find esptool.py
Re: VS Code cannot find esptool.py
Have you configure the extension using ESP-IDF: Configure ESP-IDF extension ? Did you had any problems during the setup ?
What is the value for idf.customExtraPaths ?
Users browsing this forum: No registered users and 8 guests
