Issue with null key/value's when accessing a map/vector from bluetooth_callback
ScumDrumCity
Postby ScumDrumCity » Wed Nov 11, 2020 9:09 pm
I am trying to fire a function every time an ESP32 node receives a certain char. I can receive the data and parse the char out of a packet structure I have made. I register all my actions in a map of type <char,callback_function>, where
typedef void (*callback_function)(void);
The idea being that I link all the chars to their respective functions, and when I parse a char out I can find the pointer to the function I want to fire easily. The only downside is I have to keep a reference to a global object to access this map from within the bluetooth_callback. I've been testing this for almost 2 days now, and I've written some example code without the espressif APIs. On its own, my code seems to work fine and it runs on the Arduino too. But if I let the bluetooth_callback get called after registering it with the espressif API, the behavior is undefined. The size of the map is still correct with the number of pairs I have added to it, but all of the values and keys are null or undefined, and if I try to access them I get a Guru Meditation Error. I have been trying to solve this problem a lot, and the behaviour is very strange to me. If I call the callback manually then everything seems to work, but if I let it get called by a bluetooth event, I get undefined behaviour and crashes. I'm not sure if I am doing something wrong c++ wise or if I this is an issue specific to the esp32. I could be making a dumb mistake. I have attached my arduino script, the header and cpp files of the library I was working on, and a sample application that should show what I am trying to do. Thank you for your help.
### Hardware:
Board: ESP32 Dev Module (Sparkfun ESP32 thing)
Core Installation version: 1.0.3
IDE name: Arduino IDE
Flash Frequency: 40Mhz
PSRAM enabled: no
Upload Speed: 115200
Computer OS: Windows 10
Backtrace.
Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC      : 0x400014e8  PS      : 0x00060430  A0      : 0x800d2410  A1      : 0x3ffcf1a0
A2      : 0x000000fe  A3      : 0x000000fc  A4      : 0x000000ff  A5      : 0x0000ff00
A6      : 0x00ff0000  A7      : 0xff000000  A8      : 0x800d2228  A9      : 0x3ffcf170
A10     : 0x3ffbed90  A11     : 0x3f40148b  A12     : 0x3f40148b  A13     : 0x0000ff00
A14     : 0x00ff0000  A15     : 0xff000000  SAR     : 0x00000010  EXCCAUSE: 0x0000001c
EXCVADDR: 0x000000fc  LBEG    : 0x400014fd  LEND    : 0x4000150d  LCOUNT  : 0xfffffffb
Backtrace: 0x400014e8:0x3ffcf1a0 0x400d240d:0x3ffcf1b0 0x400d242d:0x3ffcf1d0 0x400d14a2:0x3ffcf1f0 0x400d1501:0x3ffcf210 0x400df881:0x3ffcf230 0x400d8362:0x3ffcf280 0x4008d83d:0x3ffcf2b0
Decoded.
PC: 0x400014e8
Decoding stack results
0x400d240d: Print::write(char const*) at C:\Users\Jake Booth\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.3\cores\esp32/Print.h line 66
0x400d242d: Print::print(char const*) at C:\Users\Jake Booth\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.3\cores\esp32\Print.cpp line 89
0x400d14a2: NodeESP::act_message(char*) at C:\Users\Jake Booth\Documents\Arduino\libraries\NodeESP\NodeESP.cpp line 336
0x400d1501: NodeESP::bluetooth_callback(esp_spp_cb_event_t, esp_spp_cb_param_t*) at C:\Users\Jake Booth\Documents\Arduino\libraries\NodeESP\NodeESP.cpp line 176
0x400df881: btc_spp_cb_handler at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/bt/bluedroid/btc/profile/std/spp/btc_spp.c line 152
0x400d8362: btc_task at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/bt/bluedroid/btc/core/btc_task.c line 110
0x4008d83d: vPortTaskWrapper at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/freertos/port.c line 143
[code]
I've highlighed line 336 below to show you easily which one it is.
The arduino sketch.
[code]
#include "NodeESP.h"
#define LED_PIN 5
#define TOGGLE_LED_CHAR 'l'
#define TURN_ON_LED_CHAR 'p'
  pinMode(LED_PIN,OUTPUT);
  char l = TOGGLE_LED_CHAR;
  char p = TURN_ON_LED_CHAR;
  esp_spp_cb_param_t ex_param;
  ex_param.data_ind.data = (uint8_t*)l;
  ex_param.data_ind.len = 1;
  //ex_param_ptr = *ex_param;
  NodeESP node_esp;
  node_esp.add_func(&p, toggle_LED);
  node_esp.add_func(&l, turn_on_LED);
  node_esp.begin("TEST_1");
//Just calling it manually works, but when the espressif API calls it I get undefined behaviour.
//  NodeESP::bluetooth_callback(ESP_SPP_DATA_IND_EVT,&ex_param);
void toggle_LED()
  Serial.println("toggle_LED()");
void turn_on_LED()
  Serial.println("turn_on_LED()");
  while(1)
    vTaskDelay(100 / portTICK_PERIOD_MS);
NodeESP.h
  NodeESP.cpp - Library for automatically connecting to and using esp32 microcontrollers
  Created by Jacob Booth 11/9/2020
#ifndef NodeESP_h
#define NodeESP_h
#include "Arduino.h"
#include <ESPmDNS.h>
#include <WiFi.h>
#include <map>
#include "esp_bt_main.h"
#include "esp_bt_device.h"
#include "esp_spp_api.h"
#include "esp_gap_bt_api.h"
//---Define buffer constants--------------------------
#define RCV_BUF_SIZE 128
#define TX_BUF_SIZE 256
//---Define communication constants-------------------
#define RFCOMM_CHANNEL 1
#define RFCOMM_MAX_FRAME_SIZE 0xffff
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! please run 'make menuconfig' to enable it
#endif
class NodeESP
  public:
    //Constructor
    NodeESP();
    //Begin
    bool begin(const char *_name);
    //Typedef
    //Variables
    uint32_t bt_handle;
    const char *_name;
    std::map<char*, callback_function> funcs;
    char rx_buf[RCV_BUF_SIZE];
    char tx_buf[RCV_BUF_SIZE];
    WiFiServer server;
    WiFiClient client;
    //Generic
    void add_func(char* command, callback_function func);
    void act_message(char* trigger);
    //Bluetooth
    void bluetooth_write(char *buf, int len);
    bool bluetooth_spp_init();
    bool bluetooth_init(const char *deviceName);
    static char parse_data(uint8_t *rcvd, uint16_t len);
    static void bluetooth_callback(esp_spp_cb_event_t event, esp_spp_cb_param_t *param);
    String toString(const IPAddress & address);
  private:
#endif
And here is NodeESP.cpp
#include <WiFi.h>
#include <map>
using namespace std;
//---State Machine Variables---
//State enum that helps the state machine track its way through
//connecting to wifi.
enum state_t {
  UNDEFINED,
  DISCONNECTED,
  WIFI_CON,
  SERVER_CON
enum comm_t {
  s,
  NONE,
  WIFI,
  BLUETOOTH,
  q
//The current communication protocol we are using
comm_t cur_comm = s;
//The current state
state_t cur_state = UNDEFINED;
char tx_buf[TX_BUF_SIZE];
//---Wifi
WiFiServer server(0);
WiFiClient client;
//---Bluetooth
uint32_t bt_handle;
void* example_obj;
//---Main Init--------------------------------------------------------
NodeESP::NodeESP()
  this->_name = "default";
  example_obj = (void*)this;
bool NodeESP::begin(const char *_name)
  this->_name = _name;
  //For testing set the current communication method to bluetooth
  cur_comm = BLUETOOTH;
  switch (cur_comm)
    case UNDEFINED:
      return false;
    case NONE:
      return false;
    case WIFI:
      return true;
    case BLUETOOTH:
      if (!this->bluetooth_init(_name))
        return false;
  return true;
//---Bluetooth Functions--------------------------------
bool NodeESP::bluetooth_init(const char *deviceName)
  //Start Bluetooth
  if (!btStart())
    return false;
  //Start BlueDroid (bluetooth stack)
  if (esp_bluedroid_init()!= ESP_OK)
    return false;
  //Enable BlueDroid
  if (esp_bluedroid_enable()!= ESP_OK)
    return false;
  //Set device name
  esp_bt_dev_set_device_name(deviceName);
  //Set sannable and discoverable
  esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_CONNECTABLE_DISCOVERABLE);
  //Init spp server
  if (!this->bluetooth_spp_init())
    return false;
  //Set send bytes to the correct callback
  //send_bytes = write_bluetooth;
  return true;
bool NodeESP::bluetooth_spp_init()
  if (esp_spp_register_callback(&bluetooth_callback) != ESP_OK)
    return false;
  if (esp_spp_init(ESP_SPP_MODE_CB) != ESP_OK)
    return false;
  if (esp_spp_start_srv(ESP_SPP_SEC_NONE, ESP_SPP_ROLE_SLAVE, 1, "") != ESP_OK)
    return false;
  return true;
void NodeESP::bluetooth_write(char *buf, int len)
  esp_spp_write(bt_handle, len, (uint8_t*)buf);
void NodeESP::bluetooth_callback(esp_spp_cb_event_t event, esp_spp_cb_param_t *param)
  switch (event)
    case ESP_SPP_SRV_OPEN_EVT:
      NodeESP* self = (NodeESP*) example_obj;
      self->bt_handle = param->srv_open.handle;
    case ESP_SPP_CL_INIT_EVT:
      esp_bt_gap_set_scan_mode(ESP_BT_SCAN_MODE_NONE);
    case ESP_SPP_OPEN_EVT:
    case ESP_SPP_DATA_IND_EVT:
      //char trig = self->parse_data(param->data_ind.data, param->data_ind.len);
      self->act_message((char*)param->data_ind.data);
    case ESP_SPP_CLOSE_EVT:
    case ESP_SPP_WRITE_EVT:
    case ESP_SPP_CONG_EVT:
  return;
//---Parsing functions-------------------------------
//TODO: Add circular buffer
char NodeESP::parse_data(uint8_t *rcvd, uint16_t len)
  char body_buf[RCV_BUF_SIZE];
  uint8_t len_buf[2];
  uint8_t rcvd_bytes = 0;
  uint8_t recive_stage = 0;
  uint16_t calc_len = 0;
  //Loop through each char recieved
  for (uint16_t i = 0; i < len; i++)
    uint8_t cur_char = rcvd[i];
    rcvd_bytes++;
    //If we haven't recieved the length or body
    //And we recieve a start delim
    if (recive_stage == 0 && cur_char == 0x7E)
      //We are ready to read the length of the message (next 2 bytes)
      recive_stage = 1;
      rcvd_bytes = 0;
    else if (recive_stage == 1)//If we are recieving the length
      //Next two bytes get stored in the length buffer
      len_buf[rcvd_bytes - 1] = cur_char;
      //If we have recieved the 2 length bytes
      if (rcvd_bytes == 2)
        //Decode the length
        calc_len = ((uint16_t)len_buf[0]) << 8 | (uint16_t)len_buf[1];
        //Ready to recieve the body
        recive_stage = 2;
        rcvd_bytes = 0;
    else if (recive_stage == 2)//If we are recieving the body
      //Store the recieved bytes
      body_buf[rcvd_bytes - 1] = cur_char;
      if (rcvd_bytes == calc_len)
        //Reset
        rcvd_bytes = 0;
        recive_stage = 0;
        return(cur_char);
  return '/';
void NodeESP::add_func(char* command, callback_function func)
  Serial.println("Added new callback...");
  std::pair<char*, callback_function>* new_pair = new std::pair<char*, callback_function>(command,func);
  this->funcs.insert(*new_pair);
void NodeESP::act_message(char* trigger)
  Serial.println("[act message]");
  Serial.print("funcs.size() = ");
  Serial.print(this->funcs.size()); //Always returns the correct size all of the time
  Serial.println("");
  for  (std::map<char*, callback_function>::iterator it = this->funcs.begin();
        it != this->funcs.end();
        ++it)
    Serial.print("funcs[i].first = ");
    Serial.print(it->first); //Line 336, accessing the first element of the iterator
    Serial.println("");       //This works properly when I don't call the function through the callback.
    if (trigger == it->first)
        (it->second)();
String NodeESP::toString(const IPAddress & address)
  return String(address[0]) + "." + address[1] + "." + address[2] + "." + address[3];
Here is an example program that shows what I want to happen and that it works correctly.
// Example program
#include <iostream>
#include <string>
#include <map>
//Global object to access the instance from within static function
class example
  public:
    example();
    void begin();
    std::map<char, callback_function> funcs;
    void add_func(char command, callback_function func);
    void do_something(char trigger);
    static void example_callback(char cb);
void* example_obj;
example::example()
void example::begin()
  //Set up everything to do with external library, peripherals, ect...
  //Register the callback with the library
  //register_callback(&example_callback);
//Static func that does something
void example::example_callback(char cb)
  //Have to do this because the args need to match the library's requirements
  example* self = (example*) example_obj;
  //Do some processing...
  self->do_something(cb);
//Add a function pointer and its command char to the vector
void example::add_func(char command, callback_function func)
    std::pair<char, callback_function>* new_pair = new std::pair<char, callback_function>(command,func);
//This function is called from the callback
void example::do_something(char trigger)
  cout << "funcs.size() = "<< (this->funcs.size())<<"\n"; //Always returns the correct size all of the time
  for  (std::map<char, callback_function>::iterator it = this->funcs.begin();
        ++it)
    cout << "funcs[i].first = "<< (it->first)<<"\n";
        (it->second)();
void callback()
    cout << "Callback Called!";
int main()
    cout << "Starting program...\n";
    cout << "Creating example object...\n";
    example ex;
    cout << "Adding some callbacks...\n";
    ex.add_func('x',callback);
    ex.add_func('y',callback);
    ex.add_func('z',callback);
    cout << "Firing callback...\n";
    example::example_callback('z');
ESP_Sprite
Re: Issue with null key/value's when accessing a map/vector from bluetooth_callback
Postby ESP_Sprite » Thu Nov 12, 2020 1:25 am
This calls add_func with a single 8-bit char value of 120, while add_func expects a char *pointer*. Whenever something tries to dereference this (as your print() does), it tries to read from address 120, which will lead to a crash. Try add_func("x", callback) instead.
Users browsing this forum: No registered users and 76 guests
