i am facing an issue that is a blocker for my delivery.
i just upgraded the IDF from ESP-IDF v4.0.1-dirty to v4.2-beta1-227-gf0e87c933-dirty
this upgrade was necessary to overcome an issue with PPP that i was facing.
more on that: https://github.com/espressif/esp-idf/issues/6005
Now, i am facing a new issue.. that is crashing on BLE connect.
I (96864) NewEsp: ESP_GATTS_CONNECT_EVT1, conn_id 0, remote 68:d4:62:2c:0e:af:
I (96864) NewEsp: CONNECT_EVT2, conn_id 0, remote 68:d4:62:2c:0e:af:
I (96864) NewEsp: CONNECT_EVT3, conn_id 0, remote 68:d4:62:2c:0e:af:
I (96874) NewEsp: CONNECT_EVT4, conn_id 0, remote 68:d4:62:2c:0e:af:
I (96884) NewEsp: ESP_GATTS_CONNECT_EVT, conn_id 0, remote 68:d4:62:2c:0e:af:
I (96894) NewEsp: CONNECT_EVT5, conn_id 0, remote 68:d4:62:2c:0e:af:
W (96894) BT_L2CAP: l2cble_start_conn_update, the last connection update command still pending.
ASSERT_ERR(node->corrupt_check == KE_LIST_PATTERN), in ke_mem.c at line 275
Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0).
Core 0 register dump:
PC : 0x40083368 PS : 0x00060034 A0 : 0x80019f39 A1 : 0x3ffbf434
0x40083368: r_assert_err at ??:?
A2 : 0x00000001 A3 : 0x00000000 A4 : 0x60008048 A5 : 0x3ffbdbe4
A6 : 0x3ffbdbe4 A7 : 0x4008328c A8 : 0x80083368 A9 : 0x3ffbf414
0x4008328c: r_assert_err at ??:?
A10 : 0x0000004c A11 : 0x0000004c A12 : 0x00000010 A13 : 0xffffffff
A14 : 0x00000000 A15 : 0xfffffffc SAR : 0x00000004 EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000 LBEG : 0x40083310 LEND : 0x40083317 LCOUNT : 0x00000000
0x40083310: r_assert_err at ??:?
0x40083317: r_assert_err at ??:?
Core 0 was running in ISR context:
EPC1 : 0x4018ad9f EPC2 : 0x40188266 EPC3 : 0x00000000 EPC4 : 0x40083368
0x4018ad9f: uart_hal_write_txfifo at C:/OLF/Development/Firmware/ESP-IDF/esp-idf_4_2/components/soc/src/hal/uart_hal_iram.c:35
0x40188266: esp_pm_impl_waiti at C:/OLF/Development/Firmware/ESP-IDF/esp-idf_4_2/components/esp32/pm_esp32.c:486
Backtrace:0x40083365:0x3ffbf434 |<-CORRUPTED
0x40083365: r_assert_err at ??:?
Core 1 register dump:
PC : 0x40188266 PS : 0x00060634 A0 : 0x800d62b1 A1 : 0x3ffbd690
A2 : 0x00000000 A3 : 0x00000000 A4 : 0x00000001 A5 : 0x80000001
A6 : 0x00000003 A7 : 0x00060023 A8 : 0x800d61b2 A9 : 0x3ffbd660
A10 : 0x00000000 A11 : 0x00000001 A12 : 0x00000014 A13 : 0x000000a5
A14 : 0x000000a5 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000005
EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
Backtrace:0x40188263:0x3ffbd690 0x400d62ae:0x3ffbd6b0 0x40090545:0x3ffbd6d0 0x4008fc29:0x3ffbd6f0
0x40188263: esp_pm_impl_waiti at C:/OLF/Development/Firmware/ESP-IDF/esp-idf_4_2/components/esp32/pm_esp32.c:484
0x400d62ae: esp_vApplicationIdleHook at C:/OLF/Development/Firmware/ESP-IDF/esp-idf_4_2/components/esp_common/src/freertos_hooks.c:63
0x40090545: prvIdleTask at C:/OLF/Development/Firmware/ESP-IDF/esp-idf_4_2/components/freertos/tasks.c:3386 (discriminator 1)
0x4008fc29: vPortTaskWrapper at C:/OLF/Development/Firmware/ESP-IDF/esp-idf_4_2/components/freertos/xtensa/port.c:143
BLE crashing on connect
Re: BLE crashing on connect
turning on BLE
I (4814) BTDM_INIT: BT controller compile version [a6525b7]
I (4814) system_api: Base MAC address is not set
I (4824) system_api: read default base MAC address from EFUSE
I (4914) phy: phy_version: 4500, 0cd6843, Sep 17 2020, 15:37:07, 0, 0
I (5254) NewEsp: REGISTER_APP_EVT, status 0, app_id 0
I (5264) NewEsp: CREATE_SERVICE_EVT, status 0, service_handle 40
I (5264) NewEsp: REGISTER_APP_EVT, status 0, app_id 1
I (5264) NewEsp: REGISTER_APP_EVT, status 0, app_id 2
I (5274) NewEsp: REGISTER_APP_EVT, status 0, app_id 3
I (5284) NewEsp: BluetoothLE has been started!
I (5294) NewEsp: SERVICE_START_EVT, status 0, service_handle 40
I (5294) NewEsp: CREATE_SERVICE_EVT, status 0, service_handle 46
I (5294) NewEsp: CREATE_SERVICE_EVT, status 0, service_handle 62
I (5304) NewEsp: CREATE_SERVICE_EVT, status 0, service_handle 78
I (5314) NewEsp: REGISTER_APP_EVT, status 0, app_id 4
I (5314) NewEsp: REGISTER_APP_EVT, status 0, app_id 5
I (5334) NewEsp: SERVICE_START_EVT, status 0, service_handle 46
I (5334) NewEsp: SERVICE_START_EVT, status 0, service_handle 62
I (5334) NewEsp: SERVICE_START_EVT, status 0, service_handle 78
I (5344) NewEsp: CREATE_SERVICE_EVT, status 0, service_handle 98
I (5344) NewEsp: CREATE_SERVICE_EVT, status 0, service_handle 102
I (5354) NewEsp: SERVICE_START_EVT, status 0, service_handle 98
I (5364) NewEsp: SERVICE_START_EVT, status 0, service_handle 102
I (28314) NewEsp: ESP_GATTS_CONNECT_EVT1, conn_id 0, remote 67:46:18:68:58:18:
I (28314) NewEsp: CONNECT_EVT2, conn_id 0, remote 67:46:18:68:58:18:
I (28324) NewEsp: CONNECT_EVT3, conn_id 0, remote 67:46:18:68:58:18:
I (28334) NewEsp: CONNECT_EVT4, conn_id 0, remote 67:46:18:68:58:18:
I (28334) NewEsp: ESP_GATTS_CONNECT_EVT, conn_id 0, remote 67:46:18:68:58:18:
I (28344) NewEsp: CONNECT_EVT5, conn_id 0, remote 67:46:18:68:58:18:
W (28354) BT_L2CAP: l2cble_start_conn_update, the last connection update command still pending.
I (28554) NewEsp: ESP_GATTS_MTU_EVT, MTU 490
I (28564) NewEsp: ESP_GATTS_MTU_EVT, MTU 490
I (28574) NewEsp: ESP_GATTS_MTU_EVT, MTU 490
I (28684) NewEsp: update connetion params status = 0, min_int = 16, max_int = 16,conn_int = 27,latency = 0, timeout = 320
I (29144) NewEsp: GATT_READ_EVT, conn_id 0, trans_id 2, handle 72
I (29144) NewEsp: READ VERSION
I (29674) NewEsp: update connetion params status = 16, min_int = 16, max_int = 16,conn_int = 27,latency = 0, timeout = 320
W (33364) NewEsp: ESP_GATTS_DISCONNECT_EVT
W (33364) NewEsp: BLE DISCONNECTED DURING OTA
I (48754) NewEsp: ESP_GATTS_CONNECT_EVT1, conn_id 0, remote 67:46:18:68:58:18:
I (48754) NewEsp: CONNECT_EVT2, conn_id 0, remote 67:46:18:68:58:18:
I (48754) NewEsp: CONNECT_EVT3, conn_id 0, remote 67:46:18:68:58:18:
I (48764) NewEsp: CONNECT_EVT4, conn_id 0, remote 67:46:18:68:58:18:
I (48774) NewEsp: ESP_GATTS_CONNECT_EVT, conn_id 0, remote 67:46:18:68:58:18:
I (48784) NewEsp: CONNECT_EVT5, conn_id 0, remote 67:46:18:68:58:18:
W (48784) BT_L2CAP: l2cble_start_conn_update, the last connection update command still pending.
A10 : 0x00000000 A11 : 0x00060623 A12 : 0x00060620 A13 : 0x00060623
A14 : 0x3ffb9fa0 A15 : 0x00000000 SAR : 0x00000000 EXCCAUSE: 0x00000005
ELF file SHA256: ddd30d642d55fd9c
Initiating core dump!
I (22201) esp_core_dump_uart: Press Enter to print core dump to UART...
I (22208) esp_core_dump_uart: Print core dump to uart...
I (22214) esp_core_dump_elf: Found tasks: 11
Core dump started (further output muted)
Received 23 kB...
Core dump finished!
Failed to run espcoredump script: Command '['C:\\OLF\\Development\\Firmware\\ESP-IDF\\.espressif\\python_env\\idf4.2_py3.8_env\\Scripts\\python.exe', 'C:\\OLF\\Development\\Firmware\\ESP-IDF\\esp-idf_4_2\\tools\\..\\components\\espcoredump\\espcoredump.py', 'info_corefile', '--core', 'C:\\Users\\SUMESH~1\\AppData\\Local\\Temp\\tmpgpgpb6nz', '--core-format', 'b64', 'c:\\olf\\development\\firmware\\olfirmware-esp32-lte-dlc\\build\\olfirmware-esp32-lte-dlc.elf']' returned non-zero exit status 1.
================= CORE DUMP START =================
gEUAAAABAAALAAAAXAEAAAAAAAA=
f0VMRgEBAQAAAAAAAAAAAAQAXgABAAAAAAAAADQAAAAAAAAAAAAAADQAIAAZACgA
AAAAAA==
BAAAAFQDAAAAAAAAAAAAACAaAAAgGgAABgAAAAAAAAA=
AQAAAHQdAABwzvs/cM77P6gBAACoAQAABgAAAAAAAAA=
AQAAABwfAACE1/s/hNf7P1wBAABcAQAABgAAAAAAAAA=
AQAAAHggAADQ1fs/0NX7P6wBAACsAQAABgAAAAAAAAA=
AQAAACQiAAAg0Ps/IND7P1wBAABcAQAABgAAAAAAAAA=
AQAAAIAjAAB08/s/dPP7P9ABAADQAQAABgAAAAAAAAA=
AQAAAFAlAAA4yPs/OMj7P1wBAABcAQAABgAAAAAAAAA=
AQAAAKwmAAAAxPs/AMT7PzAEAAAwBAAABgAAAAAAAAA=
AQAAANwqAACQ/vw/kP78P1wBAABcAQAABgAAAAAAAAA=
AQAAADgsAADA/Pw/wPz8P8gBAADIAQAABgAAAAAAAAA=
AQAAAAAuAACgn/s/oJ/7P1wBAABcAQAABgAAAAAAAAA=
AQAAAFwvAADwnfs/8J37P6gBAACoAQAABgAAAAAAAAA=
AQAAAAQxAACsdvs/rHb7P1wBAABcAQAABgAAAAAAAAA=
AQAAAGAyAADgdPs/4HT7P8QBAADEAQAABgAAAAAAAAA=
AQAAACQ0AABUX/s/VF/7P1wBAABcAQAABgAAAAAAAAA=
AQAAAIA1AABgN/0/YDf9P+wBAADsAQAABgAAAAAAAAA=
AQAAAGw3AADoR/0/6Ef9P1wBAABcAQAABgAAAAAAAAA=
AQAAAMg4AAAARv0/AEb9P+ABAADgAQAABgAAAAAAAAA=
AQAAAKg6AAA4Yv0/OGL9P1wBAABcAQAABgAAAAAAAAA=
AQAAAAQ8AABQYP0/UGD9P+ABAADgAQAABgAAAAAAAAA=
AQAAAOQ9AACcWfs/nFn7P1wBAABcAQAABgAAAAAAAAA=
AQAAAEA/AABQKf0/UCn9P/gBAAD4AQAABgAAAAAAAAA=
AQAAADhBAAA8mvs/PJr7P1wBAABcAQAABgAAAAAAAAA=
AQAAAJRCAAAwffs/MH37P8ABAADAAQAABgAAAAAAAAA=
BAAAAFREAAAAAAAAAAAAABQBAAAUAQAABgAAAAAAAAA=
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAhNf7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAZoIYQCQGBgAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALFiDYCQ1vs/
AAAAAAAAAAABAAAAAQAAgAMAAAAjAAYAsmENgGDW+z8AAAAAIwYGACAGBgAjBgYA
oJ/7PwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIND7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaDMIQCQABgAQMwhAFzMIQAAAAAAEAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADmfAYA09Ps/
AQAAAAAAAABIgABg5Nv7P+Tb+z+MMghAaDMIgBT0+z9MAAAATAAAABAAAAD/////
AAAAAPz///8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOMj7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCAPBgDgwgBA9sIAQP////8gAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgqCYDAxPs/
AAAAAAQAAADsnfw/IwkGAAMAAAAjAAYAkBoIgKDE+z/cAPA/AQAAAKDs+z8jCwYA
gBBAPwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkP78PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCAKBgAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKYdCYCA/fw/
AAAAAAAAAAAs2fs/AAAAAAAAAAAjCgYAkBoIgGD9/D/cAPA/AQAAAKDs+z+Qo/s/
aFYNQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoJ/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACCoJQCAIBgAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFOdCICwnvs/
oH/7PwAAAADof/s/AAAAAAEAAAABAAAACCoJgJCe+z8BAAAABAAAAPCd/D9Mf/s/
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAArHb7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCAJBgDgwgBA9sIAQP////8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgqCYCgdfs/
AAAAAAAAAADsnfw/qwIAACgFQD8AAAAAkBoIgIB1+z/cAPA/AQAAAKDs+z8jCQYA
PJ0IQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAVF/7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCAHBgBsxABAd8QAQAAAAAAEAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgqCYAgOP0/
AAAAAAAAAADsnfw/AAAAAAAAAAAGAAAAkBoIgAA4/T/cAPA/AQAAAKDs+z8jBwYA
QAEAANBg+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA6Ef9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCAHBgDgwgBA9sIAQP////8ZAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgqCYDARv0/
AAAAAAAAAADsnfw/AAAAAAAAAADoR/0/kBoIgKBG/T/cAPA/AQAAAKDs+z8jBwYA
wpFBP/sAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOGL9PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCAHBgD9FABADRUAQPn///8EAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgqCYAQYf0/
AAAAAAAAAADsnfw/AAAAAAAAAAADAAAAkBoIgPBg/T/cAPA/AQAAAKDs+z8jBwYA
/P///w4AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAnFn7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCAHBgDgwgBA9sIAQP////8cAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgqCYAQKv0/
AAAAAAAAAADsnfw/////BwAAAAAAAAAAkBoIgPAp/T/cAPA/AQAAAKDs+z8jBwYA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPJr7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAkBoIQCALBgAAAAAAAAAAAAAAAAAPAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgqCYDwffs/
AAAAAAAAAADsnfw/THr7PxQL/D8jAQYAkBoIgNB9+z/cAPA/AQAAAKDs+z8jCwYA
8KT7P/yk+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
LCUIQGaCGEAwCQYAsWINgDDP+z8AAAAAAQAAAAEAAAABAACA4ADwPwEAAACyYQ2A
AM/7PwAAAAABAAAAjc0IgNT0+z8AAAAAAAAAAAAAAAD//wAAAAAAAAAAAAAAAAAA
AAAAADAnCEDU9Ps/PP4IQJA9+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAABIBQmAUM/7PwgAAAAAAAAA
AQAAAAEAAIDgAPA/AQAAACz8CIBwz/s/AAAAAAAAAAABAAAAIwAGAAMAAAAjAAYA
AAAAAJDP+z88BQlAAAAAACMABgAAnPw/hNf7PwAAAAAAAAAAsM/7PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALzP+z8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
0NX7PxDX+z+dYKPZAJz8PyjQ+z+E1/s/+Jv8PxkAAAD1m8VwOqwIPITX+z8AAAAA
AAAAAIDR+z9JRExFMQCB7Te0OOjchBkAAQAAAHzX+z8AAAAAAAAAAAAAAAAAAAAA
AAAAALBk+z8YZfs/gGX7PwAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAEgdAEAAAAAA
AAAAAAAAAAAAC12o
LCUIQGaCGEA0BgYAsWINgJDW+z8AAAAAAAAAAAEAAAABAACAAwAAACMABgCyYQ2A
YNb7PwAAAAAjBgYAIAYGACMGBgCgn/s/AAAAAAAAAAD//wAAAAAAAAAAAAAAAAAA
AAAAACAGBgAjBgYAqBAIQPBE+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAA8BQlAAAAAAAAAAABIBQmAsNb7PwgAAAABAAAA
AAAAAAAAAAAAAAAAAAAAACz8CIDQ1vs/AAAAAAAAAAABAAAAIwAGABSb/D8AAAAA
AAAAAPDW+z88BQlAAAAAACMABgAAnPw/IND7PwAAAAAAAAAAENf7PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABzX+z8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
cM77P7DP+z/yIR5EjNf7PwCc/D8g0Ps/+Jv8PxkAAABC9CuZiJjNvCDQ+z8AAAAA
AAAAABzK+z9JRExFMAAdi1Mrmw3+boQAAAAAABjQ+z8AAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAACDLA
776t3mgzCEA0AAYAOZ8BgDT0+z8BAAAAAAAAAEiAAGDk2/s/5Nv7P4wyCEBoMwiA
FPT7P0wAAABMAAAAEAAAAP////8AAAAA/P///wQAAAAFAAAAAAAAABAzCEAXMwhA
AAAAABAAAAD/////qBAIQJA9+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAQ7+z9COvs/QDr7P2j9+j+ZdgiAVPT7P8AF+z8AAAAA
AAAAAAEAAAARAAAAAABAAehgCICE9Ps/rIn8P7SeAUAAAAAAAQAAAEgHAAABAAAA
PDr7PxQAAADMk/s/YIP7P3heCIDE9Ps/2Dv7PwEAAAAAAAAAAAAAAAAAAAAAWPs/
ADz7PwEAAABIAAAA2Dv7PwAAAAAGAAAAkgn7PwAAAABBhAiA5PT7P7heCEDYO/s/
0HUIQKiJ/D8AAAAAIQ4GAE6VCIAE9fs/CAAAAIAAAACoifw/8FQBQAMAAAAjCQYA
mCcIQCT1+z+oifw/AQAAAHSS+z8IAAAAQI37P5BdCEBmghhARPX7P+AA8D/Y/fs/
smENgDz+CEAAAAAAAQAAALFiDYAwz/s/AAAAAAAAAAA=
AMT7P9DH+z++EgAA7Jv8P+yb/D84yPs/5Jv8PxgAAAAMCv0/DAr9PzjI+z8ECv0/
AQAAAHym+z9tYWluAEzOdQc7OZzJWkoAAAAAADDI+z8BAAAAAQAAAAAAAAAAAAAA
AAAAAAAAAAAAY9a0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LCUIQJAaCEAwCgYAph0JgID9/D8AAAAAAAAAACzZ+z8AAAAAAAAAACMKBgCQGgiA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LCUIQAgqCUAwCAYAU50IgLCe+z+gf/s/AAAAAOh/+z8AAAAAAQAAAAEAAAAIKgmA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LCUIQJAaCEAwCQYACCoJgKB1+z8AAAAAAAAAAOyd/D+rAgAAKAVAPwAAAACQGgiA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LCUIQJAaCEAwBwYACCoJgCA4/T8AAAAAAAAAAOyd/D8AAAAAAAAAAAYAAACQGgiA
ADj9P9wA8D8BAAAAoOz7PyMHBgBAAQAA0GD7PwQAAAD//wAAAAAAAGzEAEB3xABA
AAAAADAnCEAjBwYAPP4IQMCm+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAEmXDoAwOP0/hHf9PxAAAAAwxRCAQDj9P1he+z8AAAAA
ZKgQgFA4/T/sdP0/hHf9P4rCEICAOP0/CFz7P/////8AAAAAthIAAOx0/T/shP0/
/////4A4/T/cd/0/BHj9P6Be+z8AAAAAAQAAAAAOAAAs/AiAoDj9PwIAAAACAAAA
IFz7PyMABgADAAAAIwwGAAAAAADAOP0/eMIQQCDG+z/4W/s/fJ38P1Rf+z8AAAAA
AAAAAOA4/T8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAADsOP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
AEb9P4BH/T+AaDhyQGL9P1xf+z/oR/0/dJv8PwMAAAAUPf0/FD39P+hH/T8MPf0/
FgAAAOQ9/T9oY2lUAGm8HWjhvP3yu5kAAAAAAOBH/T8WAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAbP1g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LCUIQJAaCEAwBwYACCoJgBBh/T8AAAAAAAAAAOyd/D8AAAAAAAAAAAMAAACQGgiA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LCUIQJAaCEAwBwYACCoJgBAq/T8AAAAAAAAAAOyd/D////8HAAAAAAAAAACQGgiA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LCUIQJAaCEAwCwYACCoJgPB9+z8AAAAAAAAAAOyd/D9Mevs/FAv8PyMBBgCQGgiA
0H37P9wA8D8BAAAAoOz7PyMLBgDwpPs//KT7Pw8AAAD//wAAAAAAAAAAAAAAAAAA
AAAAADAnCEAjCwYAPP4IQHDs+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAACwlCEAk/AhAMAAFAAAAAABTnQiAEH77P6B6+z8AAAAA
AAAAADydCEAAAAAAAAAAACz8CIBQfvs/AAAAAIjj/D8AAAAAJQAAAAAAAAAAAAAA
/////1B++z8AAAAAdJsYQOh6+z8AAAAAAQAAAAIAAAAAAAAAcH77PzydCEAAAAAA
iOP8P+Cd/D88mvs/AQAAAAAAAACQfvs/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
nRcIgLA7/j9cm/w/KAVAPwAAAAAAAAAAnH77PwAAAAAAAAAAAAAAAAAAAAAAAAAA
FAAAAEgAAABKIAAA
RVNQX0NPUkVfRFVNUF9JTkZPAAA=
AAEAAGRkZDMwZDY0MmQ1NWZkOWMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
DAAAAJQAAAClAgAA
RVhUUkFfSU5GTwAA
IND7P+gAAAAFAAAA7gAAAAAAAADCAAAAIAkGAMMAAAAAAAAAxAAAACIABgDFAAAA
AAAAAMYAAAAAAAAAsQAAAH5MDUCyAAAAZoIYQLMAAAAAAAAAtAAAAGgzCEC1AAAA
AAAAALYAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAA==
y0p0xg==
================= CORE DUMP END =================
Received 23 kB...
Core dump finished!
AAAAAA==
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAA
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
CAAAAEwCAAABAAAA
Q09SRQAAAAA=
AAAAAAAAAAAAAAAA
AAAAAAAAAAAAC12o
AAAAAAAAAAAACDLA
AAAAAAAAAAAAY9a0
AAAAAAAAAAAAdVCj
AAAAAAAAAAAAO3Xj
AAAAAAAAAAAAX9V5
AAAAAAAAAAAAAOYA
AAAAAAAAAAAAAAAA
AAAAAAAAAAAAbP1g
AAAAAAAAAAAAQIfB
AAAAAAAAAAAAzRgH
AAAAAAAAAAAAjw0e
FAAAAEgAAABKIAAA
DAAAAJQAAAClAgAA
RVhUUkFfSU5GTwAA
AAAAAA==
y0p0xg==
Hard to say. May be memory corruption; you can try to enable debug options in the heap memory allocator subsection in menuconfig.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 85 guests
