Installing Eclipse Plugin: Warning Message
kevin1
Postby kevin1 » Thu Oct 22, 2020 10:21 pm
Using reference https://github.com/espressif/idf-eclipse-plugin
eclipse Plugin 23102020.txt
(10.07 KiB) Downloaded 437 times
install output.
WARNING: directory for tool riscv-none-embed-gcc version riscv-none-embed-gcc-8.2.0 is present, but tool was not found
Which file is the "Installing ESP-IDF Tools" procedure looking for?
Missing Tool 23102020.png (106.06 KiB) Viewed 2726 times
Your advice would be much appreciated.
Kevin
kevin1
Re: Installing Eclipse Plugin: Warning Message
Postby kevin1 » Sun Oct 25, 2020 7:46 pm
Success with flash:
eclipse flash.png (142.28 KiB) Viewed 2693 times
Terminal COM ok:
eclipse serial terminal.png (122.93 KiB) Viewed 2693 times
(1.81 MiB) Downloaded 443 times
Next Debugging.
Users browsing this forum: No registered users and 14 guests
