ESP32-PICO-D4 ST7735 180x60 deep sleep
biccius
Postby biccius » Fri Oct 16, 2020 10:09 pm
I'm programming a LilyGo T-Wristband with Arduino core (no esp-idf) using ESP32-PICO-D4.
A ST7735 0.96" 160x80 TFT screen is connected using SPI and TFT_eSPI is the graphical library used to manage the display.
A TP button is used to wake up the chip from deep sleep mode.
Schematics and more informations are at the end of this post.
My purpose is to try to:
a. init display at the start then fill the screen with a color A
b. send the esp32 to deep sleep
c. wake up with button press the esp32 and redraw the display with color A avoiding to re-initialize the display cause it's already set
d. then change in progression colors to B, C , etc..
On "c" phase i don't want to re-initialize the display everytime i wake from a deep sleep because is a slow operation.
I assume the display is already initialized and just wake it up from sleep as fast as possible.
So i'm trying with this code to keep the RESET pin high (gpio_hold_en) and switch off the display (DISPOFF) and sending it to sleep (SLPIN)-
#include <TFT_eSPI.h>
#include <SPI.h>
#include <WiFi.h>
#include <Wire.h>
#include "sensor.h"
#include "esp_adc_cal.h"
#define TP_PIN_PIN          		33		// wakeup pin
#define TP_PWR_PIN 			25		// power for the touch button
TFT_eSPI tft = TFT_eSPI();       // Invoke library, pins defined in User_Setup.h
RTC_DATA_ATTR int boots = 0;
void setupTFT()
  tft.init();
  tft.setRotation(1);
  tft.setSwapBytes(true);
int color = 0x5555;
void Wake()
    pinMode(TFT_CS, OUTPUT);
    pinMode(TFT_DC, OUTPUT);
    pinMode(TFT_BL, OUTPUT);
    digitalWrite( TFT_BL , HIGH);	//backlight on
    SPI.begin(TFT_SCLK, TFT_MISO, TFT_MOSI, -1);
    tft.writecommand(ST7735_DISPON);	// display on
    delay(150);
    tft.writecommand(ST7735_SLPOUT);	// display sleep off
    delay(150);
void Sleep()
  tft.writecommand(ST7735_SLPIN);  // display sleep on
  delay(150);
  tft.writecommand(ST7735_DISPOFF);  // display off
  delay(200);
  digitalWrite(GPIO_NUM_26, HIGH);  	// keep GPIO_26 high state after deep sleep reset
  gpio_hold_en(GPIO_NUM_26);		// display is preserved
  gpio_deep_sleep_hold_en();
  digitalWrite( TFT_BL , LOW);  //backlight off
  SPI.end();	// spi communication stopped
  esp_sleep_enable_ext1_wakeup(GPIO_SEL_33, ESP_EXT1_WAKEUP_ANY_HIGH);
  esp_deep_sleep_start();
void setup(void)
	  pinMode(TP_PIN_PIN, INPUT);
	  pinMode(TP_PWR_PIN, PULLUP);
	  //! Must be set to pull-up output mode in order to wake up in deep sleep mode
	  digitalWrite(TP_PWR_PIN, HIGH);
	  if(boots == 0) //Run this only the first time
		  Serial.println("first boot");
		  setupTFT();
		  tft.fillScreen(color);
		  color+=0x1000;
	  	  boots ++;
	  else
		  Serial.println("wake");
		  Wake();
		  tft.setRotation(1);
		  tft.setSwapBytes(1);
		  delay(3000);
		  while (1)
			  Serial.println("changing color");
			  color+=10;
			  delay(10);
	  }//if boots
void loop()
	delay(5000);
	Serial.println("sleep");
	Sleep();
Code seems to work properly but in "d" phase i get the display not full filled by a new color like in figure:
Is there something wrong?
What can be the cause and how to fix it?
Thank you
PIN DEFINITION
  • TFT_MOSI 19
  • TFT_SCLK 18
  • TFT_CS 5
  • TFT_DC 23
  • TFT_RST 26
  • TFT_BL 27
  • Touchpad 33
  • Touchpad Power 25
RESOURCES
Users browsing this forum: No registered users and 105 guests
