ADC1 GPIO 32/32 and ADC2 GPIO 13/15 difference?
jsyzthz
Postby jsyzthz » Sat Oct 10, 2020 7:50 am
we desigin a dev board using ESP32 WROOM-32D, we found the same input sensor(AD) 32& 33 value are same, 13&15 are same . 32/33 and 13/15 are difference.
same arduino code:
void setup(){
  u8g2.drawUTF8(1, 1, String(analogRead(13)).c_str());
  u8g2.drawUTF8(1, 15, String(analogRead(15)).c_str());
  u8g2.drawUTF8(1, 30, String(analogRead(32)).c_str());
  u8g2.drawUTF8(1, 45, String(analogRead(33)).c_str());
void loop(){
//todo
the wifi not enable. just turn on bluetooth.
who know what the difference between ADC1 AND ANDC2 when read the AD value ? thx!
lbernstone
Re: ADC1 GPIO 32/32 and ADC2 GPIO 13/15 difference?
Postby lbernstone » Sat Oct 10, 2020 6:39 pm
ADC2 is not available while the radio is in use.
When not in use, the two ADC channels give reasonably similar response, but should be calibrated separately if you want really accurate results. https://docs.espressif.com/projects/esp ... alibration
Users browsing this forum: No registered users and 81 guests
