Is there a way to control the LED that's used for "flashing" when a picture is being grabbed into the Frame Buffer?
Is there a way to directly turn that LED on and off?
Is there a way to control the brightness when it's on?
Is there a way to DISABLE it so that it does not flash when a picture is being grabbed into the Frame Buffer?
Controlling the LED
Re: Controlling the LED
On what hardware? In general, LEDs like that tend to be connected to a GPIO; in that case you should be able find the lines that control it in software.
On the ESP32-CAM something like this should work.
Full code is here: https://github.com/robotzero1/esp32cam- ... fieCam.ino
I'm not sure you can do PWM on that pin.
Your RGB888 tests here https://www.esp32.com/viewtopic.php?f=32&t=17479 were interesting. I learnt a lot from this thread.
pinMode(4, OUTPUT);// initialize io4 as an output for LED flash.
digitalWrite(4, LOW); // flash off/
void smile(){
digitalWrite(4, HIGH); // flash on
take_photo();
