I got the problem while starting debug in VSCode via ESP-IDF Debug Adapter
So when I lanch debug, debug not starting.
Step buttons disabled (see attachment)
OpenOCD and ESP-IDF Debug Adapter logs in attachment.
My lunch.json:
"version": "0.2.0",
"configurations": [
"type": "espidf",
"name": "Launch",
"request": "launch",
"debugPort": 3333,
"logLevel": 2,
"mode": "auto",
Thank you!
VSC debug start problem.
- VSCode Debug mode.PNG (89.07 KiB) Viewed 3031 times
- OpenOCD.log
- (16.9 KiB) Downloaded 446 times
- ESP-IDF Debug Adapter.log
- (248 Bytes) Downloaded 453 times
Re: VSC debug start problem.
I got solution.
Espressivf`s debug adapter for strange reason doesn`t starts on my machine.
Debuger via "Microsoft C/C++" extetion works, but buggy: works slow, starts randomly, need manual breakpoint add in the begin of app_main() function (tried to use "thb app_main" cmd, but it doesn`t work)
Thanks to Adam-U for the article at
https://github.com/Adam-U/ESP32_VSCode_Debug
At this moment only "Native Debug " works perfectly: fast, always starts.
Just add to launch.json:
And don`t forget start OpenOCD before launch.
By the way,
The default VSCode theme makes debugging line not visible.
To change color, use this property in settings
"workbench.colorCustomizations": {
"editor.lineHighlightBackground": "#44475a"
- "version": "0.2.0",
- "configurations": [
- "type": "gdb",
- "request": "launch",
- "name": "Launch Program",
- "target": "${workspaceFolder}\\build\\${command:espIdf.getProjectName}.elf",
- "cwd": "${workspaceFolder}",
- "gdbpath": "path\\to\\xtensa-esp32-elf-gdb.exe",
- "autorun": [
- "target remote localhost:3333",
- "mon reset halt",
- "flushregs",
- "thb app_main",
- "c"
By the way,
Users browsing this forum: No registered users and 21 guests
