panic error
gibrancurtiss
panic error
Postby gibrancurtiss » Sat Aug 22, 2020 5:28 pm
Hi guys.
I´tring to connect 2 ESPs and I´m getting this panic error.
Where do I have to start my search for the error?
Thank you !
 - Created client
 - Connected to server
 - Found our service
 - Found our characteristic
The characteristic value was: BLE server ok!
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC      : 0x400d4edb  PS      : 0x00060330  A0      : 0x800d474a  A1      : 0x3ffc85c0
A2      : 0x00000000  A3      : 0x3ffc85fe  A4      : 0x00000002  A5      : 0x00000000
A6      : 0x3ffdf2b0  A7      : 0x3f018640  A8      : 0x800d44e0  A9      : 0x3ffc8570
A10     : 0x3ffc85bc  A11     : 0xb9e9324a  A12     : 0x3ffc5280  A13     : 0xb9e9324a
A14     : 0x0000008e  A15     : 0xff000000  SAR     : 0x00000018  EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000030  LBEG    : 0x4000c2e0  LEND    : 0x4000c2f6  LCOUNT  : 0x00000000
Backtrace: 0x400d4edb:0x3ffc85c0 0x400d4747:0x3ffc85f0 0x400d1ce6:0x3ffc8640 0x400d1d7a:0x3ffc8690 0x400d7599:0x3ffc86f0 0x4008e089:0x3ffc8710
Rebooting...
ESP_Sprite
Re: panic error
Postby ESP_Sprite » Sat Aug 22, 2020 6:03 pm
I'd suggest you start by trying to decode that backtrace. If you use 'make monitor' or 'idf.py monitor' as your terminal program, it should do that automatically.
spairo
Re: panic error
Postby spairo » Sat Aug 22, 2020 6:45 pm
or try used "EspExceptionDecoder-1.1.0"
Users browsing this forum: No registered users and 85 guests
