BLE characteristic readValue cannot reliably read data
lightingghost
Postby lightingghost » Thu Aug 20, 2020 8:40 pm
I am trying to read the value from a characteristic of a BLE device. The code
#include <Arduino.h>
#include "BLEDevice.h"
//#include "BLEScan.h"
static const char* TAG = "CtrlMain";
static BLEUUID heightServiceUUID("99fa0020-338a-1024-8a49-009c0215f78a");
static BLEUUID heightCharUUID("99fa0021-338a-1024-8a49-009c0215f78a");
static BLEUUID motionServiceUUID("99fa0001-338a-1024-8a49-009c0215f78a");
static BLEUUID motionCharUUID("99fa0002-338a-1024-8a49-009c0215f78a");
static BLEAddress deskAddress("e2:70:5c:5b:d3:26");
static boolean connected = false;
static BLERemoteCharacteristic* pHeightCharacteristic;
static BLERemoteCharacteristic* pMotionCharacteristic;
static BLEAdvertisedDevice* desk;
typedef struct {
  uint16_t height;
  int16_t speed;
} MotionData, *PMotionData;
static void notifyCallback(
  BLERemoteCharacteristic* pBLERemoteCharacteristic,
  uint8_t* pData,
  size_t length,
  bool isNotify) {
    log_i("Notify callback for characteristic %s",
          pBLERemoteCharacteristic->getUUID().toString().c_str());
    if (pBLERemoteCharacteristic->getUUID().toString() != heightCharUUID.toString()) {
      return;
    PMotionData motion = (PMotionData) pData;
    log_i("Height: %d, Speed: %d", motion->height, motion->speed);
static int16_t readHeight() {
  if (pHeightCharacteristic == nullptr) return -1;
  //std::string val = pHeightCharacteristic->readValue();
  std::string val2 = pHeightCharacteristic->readValue();
  PMotionData motion = (PMotionData) val2.c_str();
  log_d("Height: %d, Speed: %d", motion->height, motion->speed);
  return motion->height;
class MyClientCallback : public BLEClientCallbacks {
  void onConnect(BLEClient* pclient) {
  void onDisconnect(BLEClient* pclient) {
    connected = false;
    log_i("onDisconnect");
bool connectToServer() {
    log_i("Forming a connection to %s", deskAddress.toString().c_str());
    BLEClient*  pClient  = BLEDevice::createClient();
    log_i("Created client");
    pClient->setClientCallbacks(new MyClientCallback());
    pClient->connect(deskAddress, BLE_ADDR_TYPE_RANDOM);
    log_i("Connected to server");
    // Obtain a reference to the service we are after in the remote BLE server.
    BLERemoteService* pRemoteService = pClient->getService(heightServiceUUID);
    if (pRemoteService == nullptr) {
      Serial.print("Failed to find our service UUID: ");
      Serial.println(heightServiceUUID.toString().c_str());
      pClient->disconnect();
      return false;
    log_i("Found height service");
    // Obtain a reference to the characteristic in the service of the remote BLE server.
    pHeightCharacteristic = pRemoteService->getCharacteristic(heightCharUUID);
    if (pHeightCharacteristic == nullptr) {
      Serial.print("Failed to find our characteristic UUID: ");
      Serial.println(heightCharUUID.toString().c_str());
      return false;
    log_i("Found height characteristic");
    if(pHeightCharacteristic->canNotify()){
      log_i("Set height characteristic notify");
      pHeightCharacteristic->registerForNotify(notifyCallback);
    if (pHeightCharacteristic->canRead()) {
      log_i("Can read Height");
      readHeight();
      uint8_t* rawData = pHeightCharacteristic->readRawData();
      if (rawData != nullptr) {
        Serial.println((char*)rawData);
    connected = true;
    // pClient->disconnect();
    return true;
  esp_log_level_set("*", ESP_LOG_ERROR);
  esp_log_level_set("CtrlMain", ESP_LOG_VERBOSE);
  // esp_log_level_set("bluetooth", ESP_LOG_VERBOSE);
  log_i("Starting Arduino BLE Client application...");
  BLEDevice::init("");
  connectToServer();
} // End of setup.
// This is the Arduino main loop function.
  if (connected) {
    String newValue = "Time since boot: " + String(millis()/1000);
    Serial.println("Setting new characteristic value to \"" + newValue + "\"");
  delay(1000); // Delay a second between loops.
} // End of loop
Sometimes it can read the characteristic value, with the log of
[I][ikea_desk.ino:126] setup(): Starting Arduino BLE Client application...
[I][ikea_desk.ino:70] connectToServer(): Forming a connection to e2:70:5c:5b:d3:26
[V][BLEDevice.cpp:60] createClient(): >> createClient
[V][BLEDevice.cpp:66] createClient(): << createClient
[I][ikea_desk.ino:73] connectToServer(): Created client
[V][BLEClient.cpp:96] connect(): >> connect(e2:70:5c:5b:d3:26)
[I][BLEDevice.cpp:593] addPeerDevice(): add conn_id: 0, GATT role: client
[D][FreeRTOS.cpp:189] take(): Semaphore taking: name: RegEvt (0x3ffdd16c), owner: <N/A> for connect
[D][FreeRTOS.cpp:198] take(): Semaphore taken:  name: RegEvt (0x3ffdd16c), owner: connect
[V][FreeRTOS.cpp:63] wait(): >> wait: Semaphore waiting: name: RegEvt (0x3ffdd16c), owner: connect for connect
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 0
[D][BLEDevice.cpp:148] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... Unknown
[V][BLEUtils.cpp:1283] dumpGattClientEvent(): GATT Event: Unknown
[D][BLEClient.cpp:158] gattClientEventHandler(): gattClientEventHandler [esp_gatt_if: 4] ... Unknown
[V][FreeRTOS.cpp:143] give(): Semaphore giving: name: RegEvt (0x3ffdd16c), owner: connect
[V][FreeRTOS.cpp:77] wait(): << wait: Semaphore released: name: RegEvt (0x3ffdd16c), owner: <N/A>
[D][FreeRTOS.cpp:189] take(): Semaphore taking: name: OpenEvt (0x3ffdd3c0), owner: <N/A> for connect
[D][FreeRTOS.cpp:198] take(): Semaphore taken:  name: OpenEvt (0x3ffdd3c0), owner: connect
[V][FreeRTOS.cpp:63] wait(): >> wait: Semaphore waiting: name: OpenEvt (0x3ffdd3c0), owner: connect for connect
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 40
[D][BLEDevice.cpp:577] updatePeerDevice(): update conn_id: 4, GATT role: client
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 2
[V][FreeRTOS.cpp:143] give(): Semaphore giving: name: OpenEvt (0x3ffdd3c0), owner: connect
[V][FreeRTOS.cpp:77] wait(): << wait: Semaphore released: name: OpenEvt (0x3ffdd3c0), owner: <N/A>
[V][BLEClient.cpp:129] connect(): << connect(), rc=1
[I][ikea_desk.ino:78] connectToServer(): Connected to server
[V][BLEClient.cpp:377] getService(): >> getService: uuid: 99fa0020-338a-1024-8a49-009c0215f78a
[V][BLEClient.cpp:413] getServices(): >> getServices
[V][BLEClient.cpp:71] clearServices(): >> clearServices
[V][BLEClient.cpp:78] clearServices(): << clearServices
[D][FreeRTOS.cpp:189] take(): Semaphore taking: name: SearchCmplEvt (0x3ffdd420), owner: <N/A> for getServices
[D][FreeRTOS.cpp:198] take(): Semaphore taken:  name: SearchCmplEvt (0x3ffdd420), owner: getServices
[V][FreeRTOS.cpp:63] wait(): >> wait: Semaphore waiting: name: SearchCmplEvt (0x3ffdd420), owner: getServices for getServices
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 7
[V][BLERemoteService.cpp:26] BLERemoteService(): >> BLERemoteService()
[V][BLERemoteService.cpp:34] BLERemoteService(): << BLERemoteService()
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 6
[V][FreeRTOS.cpp:143] give(): Semaphore giving: name: SearchCmplEvt (0x3ffdd420), owner: getServices
[V][FreeRTOS.cpp:77] wait(): << wait: Semaphore released: name: SearchCmplEvt (0x3ffdd420), owner: <N/A>
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 18
[V][BLEClient.cpp:430] getServices(): << getServices
[V][BLEClient.cpp:390] getService(): << getService: found the service with uuid: 99fa0020-338a-1024-8a49-009c0215f78a
[I][ikea_desk.ino:88] connectToServer(): Found height service
[V][BLERemoteService.cpp:162] retrieveCharacteristics(): >> getCharacteristics() for service: 99fa0020-338a-1024-8a49-009c0215f78a
[D][BLERemoteService.cpp:193] retrieveCharacteristics(): Found a characteristic: Handle: 26, UUID: 99fa0021-338a-1024-8a49-009c0215f78a
[V][BLERemoteCharacteristic.cpp:36] BLERemoteCharacteristic(): >> BLERemoteCharacteristic: handle: 26 0x26, uuid: 99fa0021-338a-1024-8a49-009c0215f78a
[V][BLERemoteCharacteristic.cpp:250] retrieveDescriptors(): >> retrieveDescriptors() for characteristic: 99fa0021-338a-1024-8a49-009c0215f78a
[D][BLERemoteCharacteristic.cpp:280] retrieveDescriptors(): Found a descriptor: Handle: 27, UUID: 00002902-0000-1000-8000-00805f9b34fb
[V][BLERemoteCharacteristic.cpp:294] retrieveDescriptors(): << retrieveDescriptors(): Found 1 descriptors.
[V][BLERemoteCharacteristic.cpp:45] BLERemoteCharacteristic(): << BLERemoteCharacteristic
[D][BLERemoteService.cpp:193] retrieveCharacteristics(): Found a characteristic: Handle: 29, UUID: 99fa0029-338a-1024-8a49-009c0215f78a
[V][BLERemoteCharacteristic.cpp:36] BLERemoteCharacteristic(): >> BLERemoteCharacteristic: handle: 29 0x29, uuid: 99fa0029-338a-1024-8a49-009c0215f78a
[V][BLERemoteCharacteristic.cpp:250] retrieveDescriptors(): >> retrieveDescriptors() for characteristic: 99fa0029-338a-1024-8a49-009c0215f78a
[E][BLERemoteCharacteristic.cpp:274] retrieveDescriptors(): esp_ble_gattc_get_all_descr: Unknown
[V][BLERemoteCharacteristic.cpp:294] retrieveDescriptors(): << retrieveDescriptors(): Found 0 descriptors.
[D][BLERemoteService.cpp:193] retrieveCharacteristics(): Found a characteristic: Handle: 31, UUID: 99fa002a-338a-1024-8a49-009c0215f78a
[V][BLERemoteCharacteristic.cpp:36] BLERemoteCharacteristic(): >> BLERemoteCharacteristic: handle: 31 0x31, uuid: 99fa002a-338a-1024-8a49-009c0215f78a
[V][BLERemoteCharacteristic.cpp:250] retrieveDescriptors(): >> retrieveDescriptors() for characteristic: 99fa002a-338a-1024-8a49-009c0215f78a
[V][BLERemoteService.cpp:209] retrieveCharacteristics(): << getCharacteristics()
[I][ikea_desk.ino:99] connectToServer(): Found height characteristic
[I][ikea_desk.ino:102] connectToServer(): Set height characteristic notify
[V][BLERemoteCharacteristic.cpp:438] registerForNotify(): >> registerForNotify(): Characteristic: uuid: 99fa0021-338a-1024-8a49-009c0215f78a, handle: 26 0x001a, props: broadcast: 0, read: 1, write_nr: 0, write: 0, notify: 1, indicate: 0, auth: 0
[D][FreeRTOS.cpp:189] take(): Semaphore taking: name: RegForNotifyEvt (0x3ffdfa24), owner: <N/A> for registerForNotify
[D][FreeRTOS.cpp:198] take(): Semaphore taken:  name: RegForNotifyEvt (0x3ffdfa24), owner: registerForNotify
[V][BLERemoteCharacteristic.cpp:323] getDescriptor(): >> getDescriptor: uuid: 00002902-0000-1000-8000-00805f9b34fb
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 38
[V][BLERemoteCharacteristic.cpp:327] getDescriptor(): << getDescriptor: found
[V][BLERemoteDescriptor.cpp:132] writeValue(): >> writeValue: handle: 27, uuid: 00002902-0000-1000-8000-00805f9b34fb
[V][BLERemoteDescriptor.cpp:151] writeValue(): << writeValue
[V][FreeRTOS.cpp:63] wait(): >> wait: Semaphore waiting: name: RegForNotifyEvt (0x3ffdfa24), owner: registerForNotify for registerForNotify
[V][FreeRTOS.cpp:143] give(): Semaphore giving: name: RegForNotifyEvt (0x3ffdfa24), owner: registerForNotify
[V][FreeRTOS.cpp:77] wait(): << wait: Semaphore released: name: RegForNotifyEvt (0x3ffdfa24), owner: <N/A>
[V][BLEUtils.cpp:951] gattClientEventTypeToString(): Unknown GATT Client event type: 9
[V][BLERemoteCharacteristic.cpp:478] registerForNotify(): << registerForNotify()
[I][ikea_desk.ino:107] connectToServer(): Can read Height
[V][BLERemoteCharacteristic.cpp:398] readValue(): >> readValue(): uuid: 99fa0021-338a-1024-8a49-009c0215f78a, handle: 26 0x1a
[D][FreeRTOS.cpp:189] take(): Semaphore taking: name: ReadCharEvt (0x3ffdf9c4), owner: <N/A> for readValue
[D][FreeRTOS.cpp:198] take(): Semaphore taken:  name: ReadCharEvt (0x3ffdf9c4), owner: readValue
[V][FreeRTOS.cpp:63] wait(): >> wait: Semaphore waiting: name: ReadCharEvt (0x3ffdf9c4), owner: readValue for readValue
[V][BLEUtils.cpp:1817] gapEventToString(): gapEventToString: Unknown event type 8 0x08
[V][BLEUtils.cpp:1049] dumpGapEvent(): Received a GAP event: Unknown event type
[V][BLEUtils.cpp:1264] dumpGapEvent(): *** dumpGapEvent: Logger not coded ***
[I][BLEDevice.cpp:253] gapEventHandler(): ESP_GAP_BLE_AUTH_CMPL_EVT
[D][BLEClient.cpp:458] handleGAPEvent(): BLEClient ... handling GAP event!
[V][FreeRTOS.cpp:143] give(): Semaphore giving: name: ReadCharEvt (0x3ffdf9c4), owner: readValue
[V][FreeRTOS.cpp:77] wait(): << wait: Semaphore released: name: ReadCharEvt (0x3ffdf9c4), owner: <N/A>
[V][BLERemoteCharacteristic.cpp:426] readValue(): << readValue(): length: 4, content: �
[D][ikea_desk.ino:55] readHeight(): Height: 1439, Speed: 0
Setting new characteristic value to "Time since boot: 3"
[V][BLEUtils.cpp:1817] gapEventToString(): gapEventToString: Unknown event type 20 0x14
But sometime it cannot, with the log of
[V][BLERemoteCharacteristic.cpp:426] readValue(): << readValue(): length: 0, content:
[D][ikea_desk.ino:55] readHeight(): Height: 0, Speed: 0
Setting new characteristic value to "Time since boot: 2"
Also if I call `readValue()` twice in a sequence, the second call seems to be able to get the data reliably.
I don't think there is something wrong with the BLE server, It has been tested on a computer and a phone.
Any help will be appreciated.
chegewara
Re: BLE characteristic readValue cannot reliably read data
Postby chegewara » Fri Aug 21, 2020 3:48 am
This is the reason:
Please compare both logs. In short, you cant read from ble server until authentication is not completed with success.
lightingghost
Postby lightingghost » Fri Aug 21, 2020 5:28 am
Thank you for pointing it out.
It seems to me that this authentication process happens inside readValue(), is it possible for me to wait for authentication?
Sorry for the noob question, but I am following the examples provided and cannot find a place to control the authentication.
Users browsing this forum: No registered users and 76 guests
