PlatformIO, ESP32 with Flash Encryption enabled - partition 0 invalid magic number
rg2000
Postby rg2000 » Wed Aug 19, 2020 6:56 pm
I have an app that has been working on the ESP32 Dev Kits for some time but I want to start encrypting it going forward.
However, when I enable Flash Encryption via menuconfig, build and upload it, I get this error on first upload:
rst:0x3 (SW_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:6912
ho 0 tail 12 room 4
load:0x40078000,len:16340
load:0x40080400,len:4460
entry 0x4008069c
E (60) flash_parts: partition 0 invalid magic number 0xa02
E (60) boot: Failed to verify partition table
E (62) boot: load partition table error!
ets Jun  8 2016 00:22:57
I am using custom partitions, so here is my partitions.csv:
# Name,   Type, SubType, Offset,   Size, Flags
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap,,,,
nvs,data,nvs,,16K,
otadata,data,ota,,8K,
phy_init,data,phy,,4K,
factory,app,factory,,1M,
ota_0,app,ota_0,,1M,
ota_1,app,ota_1,,1M,
In platform.io and menuconfig, offset is set at 0x10000.
platform.ini is as follows:
[env:esp32dev]
platform = https://github.com/platformio/platform-espressif32.git
board = esp32dev
framework = arduino
                     espidf
monitor_speed = 115200
monitor_filters = direct
board_build.partitions = partitions.csv
build_flags =
    -I include
    -I include/util
    -D CONFIG_PARTITION_TABLE_OFFSET=0x10000
platform_packages = framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#idf-release/v4.0
lib_deps =  ArduinoJson
Logging is set at warning as info creates a bootloader that’s too large.
I have run pio run -t erase and pio run -t clean before the uploads.
Any idea what I’m missing?
rg2000
Re: PlatformIO, ESP32 with Flash Encryption enabled - partition 0 invalid magic number
Postby rg2000 » Thu Aug 20, 2020 3:05 pm
I'll answer my own question. Turns out misunderstood the offset and kept pointing it to the app partition, instead of realizing its referring to the actual partition table location.
Users browsing this forum: No registered users and 75 guests
