ESP32 Deep Sleep Not Powering Down
juanleroux@gmail.com
Postby juanleroux@gmail.com » Wed Aug 19, 2020 8:35 am
Hi all,
I'd appreciate if someone could explain to me why my ESP32 module does not power down when in deep sleep mode? The ESP32 is connected to a battery shield like this: https://www.aliexpress.com/item/4000200 ... web201603_ When I measure the output of 3.3v pin it does not powe down during deep sleep. My code as follows:
#include "DHT.h"
#include <SPI.h>
#include <LoRa.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//915E6 for North America
#define BAND 915E6
// How many minutes the ESP should sleep
#define DEEP_SLEEP_TIME 5
// defines poll frequency
unsigned long previousMillis = 30000;
const long interval = 30000;
//loop counter
int counter = 0;
void goToSleep()
  // Configure the timer to wake us up!
  esp_sleep_enable_timer_wakeup(DEEP_SLEEP_TIME * 60L * 1000000L);
  Serial.println("Going To Sleep Now...");
 // Go to sleep! Zzzz
  esp_deep_sleep_start();
  //esp_light_sleep_start();
  Serial.println("Welcome");
   //SPI LoRa pins
  SPI.begin(SCK, MISO, MOSI, SS);
  //setup LoRa transceiver module
  LoRa.setPins(SS, RST, DIO0);
  while (!LoRa.begin(BAND)) {
    Serial.println(".");
    delay(500);
  Serial.println("LoRa Initializing OK!");
  delay(2000);
  // Wait a few seconds between measurements.
  unsigned long currentMillis = millis();
  if (currentMillis - previousMillis >= interval) {
    previousMillis = currentMillis;
    counter++;
    Serial.print("Pass #: ");
    Serial.println(counter);
    if (counter >= 2) {
      Serial.println("Sleep Time?...");
      goToSleep();
Any thoughts?
ESP_Sprite
Re: ESP32 Deep Sleep Not Powering Down
Postby ESP_Sprite » Wed Aug 19, 2020 12:49 pm
Why would you expect the 3.3V output to shut down?
Users browsing this forum: No registered users and 99 guests
