problem using MPU-6050 Accel/Gyro with ESP32
I am having problems getting the MPU-6050 Accelerometer & Gyro to work with my Heltec ESP32 Development board.
I can run the I2C scanner and it detects the MPU-6050 at 0x68
If I run any of the example sketches that came with the MPU6050.h library it does not get data from the MPU-6050
I tried the MPU6050_DMP6.ino and have tried various examples from the web. But it is an issue with the ESP32
The MPU-6050 works fine using the sketch on my Arduino Nano but not the ESP32
I have the MPU-6050 connected as follows:
MPU-6050 o left ESP32 on right
VCC to 3.3V
GND to GND
SDA to Pin 21
SCL to Pin 22
Any help is greatly appreciated
VCC to 3.3V
GND to GND
SDA to Pin 21
SCL to Pin 22
Re: problem using MPU-6050 Accel/Gyrp with ESP32
Does your mpu-6050 lib support the esp32 ?
It says that it does but I do not know if there are any unique things that need to be changed for the ESP32
I checked the github for the MPU6050 library and it does support ESP32
https://github.com/ElectronicCats/mpu60 ... /README.md
I have not try that lib, so cant tell.
I did some test last year, using Kolban's code and it works fine for me:
https://github.com/nkolban/esp32-snippe ... /mpu6050.c
Some times it can be the naming of the I2C pins, so you can try swop them, depending on your mpu6050 module.
I tried that snippet and on verify/compile it gives tons of errors
Arduino: 1.8.12 (Windows 10), Board: "WiFi LoRa 32(V2), Disabled, 240MHz (WiFi/BT), 921600, None, REGION_EU868, None"
C:\Users\Tony\Desktop\ESP32_Accel_SNIPPET\ESP32_Accel_SNIPPET.ino: In function 'void task_mpu6050(void*)':
ESP32_Accel_SNIPPET:43:18: error: invalid conversion from 'int' to 'gpio_num_t' [-fpermissive]
conf.sda_io_num = PIN_SDA;
ESP32_Accel_SNIPPET:44:18: error: invalid conversion from 'int' to 'gpio_num_t' [-fpermissive]
conf.scl_io_num = PIN_CLK;
ESP32_Accel_SNIPPET:93:54: error: invalid conversion from 'int' to 'i2c_ack_type_t' [-fpermissive]
ESP_ERROR_CHECK(i2c_master_read_byte(cmd, data, 0));
C:\Users\Tony\Desktop\ESP32_Accel_SNIPPET\ESP32_Accel_SNIPPET.ino:37:51: note: in definition of macro 'ESP_ERROR_CHECK'
#define ESP_ERROR_CHECK(x) do { esp_err_t rc = (x); if (rc != ESP_OK) { ESP_LOGE("err", "esp_err_t = %d", rc); assert(0 && #x);} } while(0);
In file included from C:\Users\Tony\Desktop\ESP32_Accel_SNIPPET\ESP32_Accel_SNIPPET.ino:1:0:
C:\Users\Tony\AppData\Local\Arduino15\packages\Heltec-esp32\hardware\esp32\0.0.5/tools/sdk/include/driver/driver/i2c.h:306:11: note: initializing argument 3 of 'esp_err_t i2c_master_read_byte(i2c_cmd_handle_t, uint8_t*, i2c_ack_type_t)'
esp_err_t i2c_master_read_byte(i2c_cmd_handle_t cmd_handle, uint8_t* data, i2c_ack_type_t ack);
ESP32_Accel_SNIPPET:94:54: error: invalid conversion from 'int' to 'i2c_ack_type_t' [-fpermissive]
ESP_ERROR_CHECK(i2c_master_read_byte(cmd, data+1, 0));
ESP32_Accel_SNIPPET:95:54: error: invalid conversion from 'int' to 'i2c_ack_type_t' [-fpermissive]
ESP_ERROR_CHECK(i2c_master_read_byte(cmd, data+2, 0));
ESP32_Accel_SNIPPET:96:54: error: invalid conversion from 'int' to 'i2c_ack_type_t' [-fpermissive]
ESP_ERROR_CHECK(i2c_master_read_byte(cmd, data+3, 0));
ESP32_Accel_SNIPPET:97:54: error: invalid conversion from 'int' to 'i2c_ack_type_t' [-fpermissive]
ESP_ERROR_CHECK(i2c_master_read_byte(cmd, data+4, 0));
ESP32_Accel_SNIPPET:98:54: error: invalid conversion from 'int' to 'i2c_ack_type_t' [-fpermissive]
ESP_ERROR_CHECK(i2c_master_read_byte(cmd, data+5, 1));
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
Sorry, selected wrong link, you should use MPU6050 .h & .cpp from this link:
https://github.com/nkolban/esp32-snippe ... /cpp_utils
How am I supposed to use these two files?
I do not see a download option
Plus if I just download these it will overwrite the other MPU6050 library which I am using for the accelerometer on an Arduino project
You add the two file a local file to your program and included MPU6050.h in you Main file.
This way you dont overwrite any other files.
Progress. I was able to get the MPU6050 to initialize. I don't know if it will work on any pin but I will have to test that after I get the interrupt to work.
I do not know how to setup and use a pin as an Interrupt on the ESP32. The accel/gyro generates an interrupt when data is available. Then I can view the readings when I figure this out.
I moved the MPU6050 to the first I2C bus, the one that the display is connected to.
This is SDA-Pin4 and SCL-Pin 15
The steps are as follows:
1) Load the heltec library
#include "heltec.h"
2) Now you can enable the built-in OLED display with this line
Heltec.begin(true /*DisplayEnable Enable*/, false /*LoRa Enable*/, true /*Serial Enable*/);
3) The key to getting I2C to work seems to be that now you have to initialize the display then other devices can be used
Heltec.display -> display();
4) It is time to start the wire. It defaults to SDA-Pin4 and SCL-Pin 15
Wire.begin();
5) Now you can initialize the MPU6050
mpu.initialize();
The next step would be to enable the interrupt. On the Arduino Uno all you have to do is plug the MPU6050 INT pin into Uno pin 2 and it worked right away.
But I am not sure how to setup and use a GPIO pin as an Interrupt on the Heltec board
#include "heltec.h"
Wire.begin();
mpu.initialize();
Users browsing this forum: No registered users and 95 guests
