ESP32-DevKitS Arduino IDE: Timed out waiting for packet header
dk4one
Postby dk4one » Thu Aug 06, 2020 7:02 pm
Hi everyone,
I am tinkering with the ESP32-DevKitS from ESP. I couldn't get it to receive the code from the Arduino IDE. For the specific board, I choose ESP32-DevModule. I'm not really sure if it is the correct one but otherwise I couldn't find the exact board.
The error is A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
Please let me know what I could do to make it works. As for the guide of the ESP32 DevKitS guide site, I couldn't find the exact guide to get it to work on Arduino IDE.
lbernstone
Re: ESP32-DevKitS Arduino IDE: Timed out waiting for packet header
Postby lbernstone » Fri Aug 07, 2020 2:45 am
Instructions for the devkits are at https://docs.espressif.com/projects/esp ... sh-a-board.
Using the default "esp32 dev module" in Arduino IDE is just fine. There are many articles here and on the github repo about these timeout issues (https://github.com/espressif/arduino-es ... +timed+out+). The most likely culprit is a bad usb cable. The devkits has the additional problem of an improperly mounted module (or just bad connections on the spring pins). Look carefully at the contacts and make sure each of the castellations on the module has a wire locked in place.
dk4one
Postby dk4one » Fri Aug 07, 2020 4:12 pm
Yeah, the cullbrit is the bad USB cable, it is only charge one.
Users browsing this forum: Google [Bot] and 102 guests
