Photoresistor Interrupt Issue using ESP32
juanleroux@gmail.com
Postby juanleroux@gmail.com » Wed Aug 05, 2020 8:18 am
Hi
I cannot seem to figure out why the attachInterrupt is not working. I read from the sensor fine, however the ISR is not called.
//cosntants for the pins where sensors are plugged into.
const int sensorPin = 2;
//Set up some global variables for the light level an initial value.
int lightInit;  // initial value
int lightVal;   // light reading
volatile int interruptCounter;
void IRAM_ATTR chan1_isr() {
  interruptCounter++;
void setup()
  pinMode(sensorPin, INPUT);
  attachInterrupt(digitalPinToInterrupt(sensorPin), chan1_isr, CHANGE);
  lightInit = analogRead(sensorPin);
  //we will take a single reading from the light sensor and store it in the lightCal        //variable. This will give us a prelinary value to compare against in the loop
void loop()
  lightVal = analogRead(sensorPin); // read the current light levels
  //if lightVal is less than our initial reading withing a threshold then it is dark.
  //if(lightVal - lightInit <  50)
  if(lightVal <  50)
      Serial.println(lightVal);
      Serial.println("Night Time");
      Serial.println("Count: " + String(interruptCounter));
  //otherwise, it is bright
  else
    Serial.println("Day Time");
delay(1000);
I cover the Photoresistor and uncover the sensor:
Serial output as follows:
17:39:50.430 -> 0
17:39:50.430 -> Night Time
17:39:50.430 -> Count: 0
17:40:04.453 -> 1369
17:40:04.453 -> Day Time
17:40:04.453 -> Count: 0
Any help would be greatly appreciated.
ESP_Sprite
Re: Photoresistor Interrupt Issue using ESP32
Postby ESP_Sprite » Wed Aug 05, 2020 8:29 am
I'm not 100% sure, but I'd guess analogRead may have something to do with it... do you still not get an interrupt if you remove all analogRead statements from your sketch?
Postby juanleroux@gmail.com » Thu Aug 06, 2020 1:18 am
@ESP_Sprite
Spot on, removing the analog read resolved the issue. Thank you!
Users browsing this forum: No registered users and 78 guests
