Esp32 HID gamepad project
NemethS
Postby NemethS » Tue Jul 21, 2020 11:23 am
Hello!
Im trying to make a wireless gamecontroller. Im in a trouble, since im amateur in this field. I read a lot of similar project and i managed to make a code, which results a 2 axis, 8 buttons gamepad under win 10.
My problem is the data not sending to the PC.
Please check where did i screwd it! :)
Thank you if you spend some time on me!
Sandor
#include <Arduino.h>
#include<Math.h>
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEServer.h>
#include "BLE2902.h"
#include "BLEHIDDevice.h"
#include "HIDTypes.h"
#include "HIDKeyboardTypes.h"
#include <driver/adc.h>
BLEHIDDevice* hid;
BLECharacteristic* input;
BLECharacteristic* output;
#define NUM_BUTTONS  8             // you don't need to change this value
#define NUM_AXES  2        // 6 axes to UNO, and 8 to MEGA. If you are using UNO, don't need to change this value.
typedef struct joyReport_t {
    int16_t axis[NUM_AXES];
    uint8_t button[(NUM_BUTTONS+7)/8]; // 8 buttons per byte
} joyReport_t;
joyReport_t joyReport;
void setButton(joyReport_t *joy, uint8_t button);
void clearButton(joyReport_t *joy, uint8_t button);
    uint8_t index = button/8;
    uint8_t bit = button - 8*index;
    joy->button[index] |= 1 << bit;
    //Serial.print("+");
   // Serial.println(index);
// turn a button off
    joy->button[index] &= ~(1 << bit);
   // Serial.print("-");
bool connected = false;
class MyCallbacks : public BLEServerCallbacks {
  void onConnect(BLEServer* pServer){
    connected = true;
    BLE2902* desc = (BLE2902*)input->getDescriptorByUUID(BLEUUID((uint16_t)0x2902));
    desc->setNotifications(true);
  void onDisconnect(BLEServer* pServer){
    connected = false;
 class MyOutputCallbacks : public BLECharacteristicCallbacks {
 void onWrite(BLECharacteristic* me){
    uint8_t* value = (uint8_t*)(me->getValue().c_str());
    ESP_LOGI(LOG_TAG, "special keys: %d", *value);
void taskServer(void*){
    BLEDevice::init("Esp32 Joy");
    BLEServer *pServer = BLEDevice::createServer();
    pServer->setCallbacks(new MyCallbacks());
    hid = new BLEHIDDevice(pServer);
    input = hid->inputReport(1); // <-- input REPORTID from report map
    output = hid->outputReport(1); // <-- output REPORTID from report map
    output->setCallbacks(new MyOutputCallbacks());
    std::string name = "TestCo.";
    hid->manufacturer()->setValue(name);
    hid->pnp(0x02, 0xe502, 0xa111, 0x0210);
    hid->hidInfo(0x00,0x02);
  BLESecurity *pSecurity = new BLESecurity();
//  pSecurity->setKeySize();
  pSecurity->setAuthenticationMode(ESP_LE_AUTH_BOND);
    const uint8_t report[] = {
      0x05, 0x01, /* Usage Page (Generic Desktop) */
 0x09, 0x05, /* Usage (Gamepad) */
 0xa1, 0x01, /* Collection (Application) */
 0x09, 0x01, /* Usage (Pointer) */
 /* 8 axes, signed 16 bit resolution, range -32768 to 32767 (16 bytes) */
 0xa1, 0x00, /* Collection (Physical) */
 0x09, 0x30, /* Usage (X) */
 0x09, 0x31, /* Usage (Y) */
// 0x09, 0x32, /* Usage (Analog1) */
// 0x09, 0x33, /* Usage (Analog2) */
 //0x09, 0x34, /* Usage (Analog3) */
 //0x09, 0x35, /* Usage (Analog4) */
// 0x09, 0x36, /* Usage (Analog5) */
// 0x09, 0x37, /* Usage (Analog6) */
 0x16, 0x00, 0x80, /* Logical Minimum (-32768) */
 0x26, 0xff, 0x7f, /* Logical Maximum (32767) */
 0x75, 16, /* Report Size (16) */
 0x95, 2, /* Report Count (8) */
 0x81, 0x82, /* Input (Data, Variable, Absolute, Volatile) */
 0xc0, /* End Collection */
 /* 40 buttons, value 0=off, 1=on (5 bytes) */
 0x05, 0x09, /* Usage Page (Button) */
 0x19, 1, /* Usage Minimum (Button 1) */
 0x29, 8, /* Usage Maximum (Button 40) */
 0x15, 0x00, /* Logical Minimum (0) */
 0x25, 0x01, /* Logical Maximum (1) */
 0x75, 1, /* Report Size (1) */
 0x95, 8, /* Report Count (40) */
 0x81, 0x02, /* Input (Data, Variable, Absolute) */
 0xc0 /* End Collection */
    hid->reportMap((uint8_t*)report, sizeof(report));
    hid->startServices();
    BLEAdvertising *pAdvertising = pServer->getAdvertising();
    pAdvertising->setAppearance(HID_GAMEPAD);
    pAdvertising->addServiceUUID(hid->hidService()->getUUID());
    pAdvertising->start();
    hid->setBatteryLevel(34);
    ESP_LOGD(LOG_TAG, "Advertising started!");
    delay(portMAX_DELAY);
  //Serial.println("Starting BLE work!");
  for (uint8_t ind=0; ind<NUM_AXES; ind++) {
   joyReport.axis[ind] = ind*0;
    for (uint8_t ind=0; ind<NUM_BUTTONS; ind++) {
        joyReport.button[ind] = 0;
  xTaskCreate(taskServer, "server", 20000, NULL, 5, NULL);
 if (connected) {
    joyReport.axis[ind] = random(-2000, 2000);
    //Serial.println(joyReport.axis[ind]);
    uint8_t buttonval;
    buttonval = random(0,2);
   // Serial.print(buttonval);
    if (buttonval == 1) {
       setButton(&joyReport, ind);
    else {
       clearButton(&joyReport, ind);
    //random(0,1);
   // Serial.println();
     Serial.println(joyReport.axis[0]);
    Serial.println(joyReport.axis[1]);
     Serial.println(joyReport.button[0], BIN);
    // Serial.println("-------------------------------");
    // Serial.println(sizeof(joyReport));
   // Serial.println((NUM_BUTTONS+7)/8);
    //Serial.println("-------------------------------");
 input->setValue((uint8_t*)&joyReport,sizeof(joyReport));
 input->notify();
  delay(10);
Users browsing this forum: No registered users and 57 guests
