is this possible?
if possible,how can I increase task stack size on visual studio code?
thank you for your help
how to increase task stack size on visual studio code?
Re: how to increase task stack size on visual studio code?
It is a parameter that you specify programmatically on the esp-idf task creation method API using usStackDepth as explained in the Task API here: https://docs.espressif.com/projects/esp ... ask%20size
I'm not sure why would you like to control on vscode if it is defined on each task...
Users browsing this forum: No registered users and 14 guests
