Unable to upload image (without gray strip) more than 640x480px to Google Drive - ESP-CAM via HTTP POST base64 payload
martinius96
Postby martinius96 » Mon May 25, 2020 4:46 pm
I am solving such a problem for the ESP-CAM platform ...
I have ESP-CAM, which is a microcontroller with an OV2640 camera.
I am sending the photo via HTTPS POST request to Google App Script that save it to my Google Drive.
Payload photo is base64 format. The photo is uploaded and fully visible.
Project is inspired from: https://github.com/gsampallo/esp32cam-gdrive
At using same sketch with resolution more than VGA (640x480) still gray strip on image.
It only works at a low resolution of 640x480 ... Whenever I use a higher photo resolution (800x600 or up to 1600x1200 - 2Mpix) there is a gray bar on each photo ... I suspect that the problem is the base64 payload .... I don't see any problem in software implementation, or memory, because of ESP-CAM has 4MB of external PSRAM memory.
Are there another ways how to upload a photo... What content type to use for payload? image / jpeg payload, application / x-www-form-urlencoded? Are there any other options? I'm also attaching an image of what the image that uploads to me in 800x600 or higher resolution looks like with that gray strip.
Photo in Google Drive with gray strip 800x600 or more px, 640x480 or lower pics are ok:
I would add that if I send the whole image in one color (for example, dark, the whole is black), it will be uploaded correctly without that gray strip ... Could it be that the payload is so long that it is not uploaded? I'm really annoyed about it already.. I don't know on which side is problem.... At encoding, at Google backend of that App Script??
After a few suggestions, problem can be at not using PSRAM, or base64 is almost 37% larger than image.... and for that... This payload is so long and Google is unable to process it... Can someone help me with this?
Code that I am using under Arduino IDE: (ESP Arduino Core 1.0.4):
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include "soc/soc.h"
#include "soc/rtc_cntl_reg.h"
#include "Base64.h"
#include <ESPmDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
#include "esp_camera.h"
unsigned long cas = 0;
const char* ssid     = "WiFi_SSID";   //your network SSID
const char* password = "WiFi_PASS";   //your network password
const char* myDomain = "script.google.com";
String myScript = "/macros/s/XXXXXXXXXXXXXXXXXXXXXXXXXXXX/exec";
String myFilename = "filename=ESP32-CAM.jpg";
String mimeType = "&mimetype=image/jpeg";
String myImage = "&data=";
int waitingTime = 30000; //Wait 30 seconds to google response.
#define PWDN_GPIO_NUM     32
#define RESET_GPIO_NUM    -1
#define XCLK_GPIO_NUM      0
#define SIOD_GPIO_NUM     26
#define SIOC_GPIO_NUM     27
#define Y9_GPIO_NUM       35
#define Y8_GPIO_NUM       34
#define Y7_GPIO_NUM       39
#define Y6_GPIO_NUM       36
#define Y5_GPIO_NUM       21
#define Y4_GPIO_NUM       19
#define Y3_GPIO_NUM       18
#define Y2_GPIO_NUM        5
#define VSYNC_GPIO_NUM    25
#define HREF_GPIO_NUM     23
#define PCLK_GPIO_NUM     22
WiFiClientSecure client;
const char* test_root_ca PROGMEM = \
                                   "-----BEGIN CERTIFICATE-----\n" \
                                   "MIIETDCCAzSgAwIBAgILBAAAAAABL07hSVIwDQYJKoZIhvcNAQEFBQAwVzELMAkG\n" \
                                   "A1UEBhMCQkUxGTAXBgNVBAoTEEdsb2JhbFNpZ24gbnYtc2ExEDAOBgNVBAsTB1Jv\n" \
                                   "b3QgQ0ExGzAZBgNVBAMTEkdsb2JhbFNpZ24gUm9vdCBDQTAeFw0wNjEyMTUwODAw\n" \
                                   "MDBaFw0yODAxMjgxMjAwMDBaMEwxIDAeBgNVBAsTF0dsb2JhbFNpZ24gUm9vdCBD\n" \
                                   "QSAtIFIyMRMwEQYDVQQKEwpHbG9iYWxTaWduMRMwEQYDVQQDEwpHbG9iYWxTaWdu\n" \
                                   "MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAps8kDr4ubyiZRULEqz4h\n" \
                                   "VJsL03+EcPoSs8u/h1/Gf4bTsjBc1v2t8Xvc5fhglgmSEPXQU977e35ziKxSiHtK\n" \
                                   "pspJpl6op4xaEbx6guu+jOmzrJYlB5dKmSoHL7Qed7+KD7UCfBuWuMW5Oiy81hK5\n" \
                                   "61l94tAGhl9eSWq1OV6INOy8eAwImIRsqM1LtKB9DHlN8LgtyyHK1WxbfeGgKYSh\n" \
                                   "+dOUScskYpEgvN0L1dnM+eonCitzkcadG6zIy+jgoPQvkItN+7A2G/YZeoXgbfJh\n" \
                                   "E4hcn+CTClGXilrOr6vV96oJqmC93Nlf33KpYBNeAAHJSvo/pOoHAyECjoLKA8Kb\n" \
                                   "jwIDAQABo4IBIjCCAR4wDgYDVR0PAQH/BAQDAgEGMA8GA1UdEwEB/wQFMAMBAf8w\n" \
                                   "HQYDVR0OBBYEFJviB1dnHB7AagbeWbSaLd/cGYYuMEcGA1UdIARAMD4wPAYEVR0g\n" \
                                   "ADA0MDIGCCsGAQUFBwIBFiZodHRwczovL3d3dy5nbG9iYWxzaWduLmNvbS9yZXBv\n" \
                                   "c2l0b3J5LzAzBgNVHR8ELDAqMCigJqAkhiJodHRwOi8vY3JsLmdsb2JhbHNpZ24u\n" \
                                   "bmV0L3Jvb3QuY3JsMD0GCCsGAQUFBwEBBDEwLzAtBggrBgEFBQcwAYYhaHR0cDov\n" \
                                   "L29jc3AuZ2xvYmFsc2lnbi5jb20vcm9vdHIxMB8GA1UdIwQYMBaAFGB7ZhpFDZfK\n" \
                                   "iVAvfQTNNKj//P1LMA0GCSqGSIb3DQEBBQUAA4IBAQCZIivuijLTDAd+3RsgK1Bq\n" \
                                   "lpEG2r5u13KWrVM/fvWPQufQ62SlZfLz4z0/WzEMfHmEOpeMDx+uwbzy67ig70H9\n" \
                                   "vDGp/MlC5kS+HlbKdYuySTGZ/urpcWSGeo/l1WERQ+hAuzEM4tsYi5l0OGGrJICM\n" \
                                   "+ag710nWZooYc8y8BjmLEDIODdOx9+9mExBZSMjPAcqZzJBymNs67cunu+JscI6m\n" \
                                   "nmhj7Y+3LQWJztlU9k6rHkbbMEk/9mrgAfC8zYTUOfdVjgMVcdOdNO2dxtHIqsWE\n" \
                                   "OTsN/SknUh6Dq0gjhVhQs5XGC7Mm4xYtqDDcA1BtXNEMzSqhR5rPIBvbQ4gfwvzg\n" \
                                   "-----END CERTIFICATE-----\n";
void setup()
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0);
  delay(10);
  WiFi.mode(WIFI_STA);
  Serial.println("");
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
    delay(500);
  client.setCACert(test_root_ca);
  ArduinoOTA.setPort(3232);
  ArduinoOTA
  .onStart([]() {
    String type;
    if (ArduinoOTA.getCommand() == U_FLASH)
      type = "sketch";
    else // U_SPIFFS
      type = "filesystem";
    // NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
    Serial.println("Start updating " + type);
  .onEnd([]() {
    Serial.println("\nEnd");
  .onProgress([](unsigned int progress, unsigned int total) {
    Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
  .onError([](ota_error_t error) {
    Serial.printf("Error[%u]: ", error);
    if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
    else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
    else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
    else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
    else if (error == OTA_END_ERROR) Serial.println("End Failed");
  ArduinoOTA.begin();
  Serial.println("");
  Serial.println("STAIP address: ");
  Serial.println("");
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  config.frame_size = FRAMESIZE_UXGA;  // UXGA|SXGA|XGA|SVGA|VGA|CIF|QVGA|HQVGA|QQVGA
  config.jpeg_quality = 10;
  config.fb_count = 1;
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    delay(1000);
    ESP.restart();
  if (WiFi.status() != WL_CONNECTED) {
    Serial.print(".");
    delay(500);
  ArduinoOTA.handle();
  if ((millis() - cas) >= 60000 || cas == 0) {
    cas = millis();
    saveCapturedImage();
void saveCapturedImage() {
  Serial.println("Connect to " + String(myDomain));
  client.stop();
  if (client.connect(myDomain, 443)) {
    Serial.println("Connection successful");
    camera_fb_t * fb = NULL;
    fb = esp_camera_fb_get();
    if (!fb) {
      Serial.println("Camera capture failed");
      delay(1000);
      ESP.restart();
      return;
    char *input = (char *)fb->buf;
    char output[base64_enc_len(3)];
    String imageFile = "";
    for (int i = 0; i < fb->len; i++) {
      base64_encode(output, (input++), 3);
      if (i % 3 == 0) imageFile += urlencode(String(output));
    String Data = myFilename + mimeType + myImage;
    esp_camera_fb_return(fb);
    Serial.println("Send a captured image to Google Drive.");
    client.println("POST " + myScript + " HTTP/1.1");
    client.println("Host: " + String(myDomain));
    client.println("Content-Length: " + String(Data.length() + imageFile.length()));
    client.println("Content-Type: application/x-www-form-urlencoded");
    client.println();
    client.print(Data);
    int Index;
    for (Index = 0; Index < imageFile.length(); Index = Index + 1000) {
      client.print(imageFile.substring(Index, Index + 1000));
    Serial.println("Waiting for response.");
    long int StartTime = millis();
    while (!client.available()) {
      Serial.print(".");
      delay(100);
      if ((StartTime + waitingTime) < millis()) {
        Serial.println();
        Serial.println("No response.");
        //If you have no response, maybe need a greater value of waitingTime
    Serial.println();
    while (client.available()) {
      Serial.print(char(client.read()));
    Serial.println("Connected to " + String(myDomain) + " failed.");
  client.stop();
//https://github.com/zenmanenergy/ESP8266-Arduino-Examples/
String urlencode(String str)
  String encodedString = "";
  char c;
  char code0;
  char code1;
  char code2;
  for (int i = 0; i < str.length(); i++) {
    c = str.charAt(i);
    if (c == ' ') {
      encodedString += '+';
    } else if (isalnum(c)) {
      encodedString += c;
      code1 = (c & 0xf) + '0';
      if ((c & 0xf) > 9) {
        code1 = (c & 0xf) - 10 + 'A';
      c = (c >> 4) & 0xf;
      code0 = c + '0';
      if (c > 9) {
        code0 = c - 10 + 'A';
      code2 = '\0';
      encodedString += '%';
      encodedString += code0;
      encodedString += code1;
      //encodedString+=code2;
    yield();
  return encodedString;
Google App Script for saving photo to my Google Drive --> ESP-CAM directory:
function doPost(e) {
  var data = Utilities.base64Decode(e.parameters.data);
  var nombreArchivo = Utilities.formatDate(new Date(), "GMT+1", "dd.MM HH:mm")+".jpg";
  var blob = Utilities.newBlob(data, e.parameters.mimetype, nombreArchivo );
  var folder, folders = DriveApp.getFoldersByName("ESP32-CAM");
  if (folders.hasNext()) {
    folder = folders.next();
    folder = DriveApp.createFolder("ESP32-CAM");
  var file = folder.createFile(blob);
  return ContentService.createTextOutput("Completed.")
Thanks for help! - Martin
martinius96
Re: Unable to upload image (without gray strip) more than 640x480px to Google Drive - ESP-CAM via HTTP POST base64 paylo
Postby martinius96 » Fri May 29, 2020 5:25 pm
Solve, Google don't accept that long Base64 payload.. So you can only send 640x480 image, not bigger :(
Users browsing this forum: No registered users and 98 guests
