Can I change the bootup settings in Arduino IDE? E.g. Boot log or flash mode
edmondng17
Postby edmondng17 » Sun May 24, 2020 3:24 pm
I want to speed up the ESP32 bootup to as short as possible. I read that it should be possible to speed up by changing various settings like bootloader log level from this thread https://www.reddit.com/r/esp32/comments ... oot_speed/
I am wondering if it is possible to change them through Arduino IDE alone. Or is there any way of making it faster through Arduino IDE alone?
Thanks for any help.
lbernstone
Re: Can I change the bootup settings in Arduino IDE? E.g. Boot log or flash mode
Postby lbernstone » Tue May 26, 2020 3:46 pm
You cannot modify the bootloader in arduino-esp32- they are pre-compiled. Use esp-idf or lib-builder if you want more control.
The only interaction you can have with the bootloader is hardware level. That's why there is a strapping pin to disable the logging.
edmondng17
Postby edmondng17 » Thu May 28, 2020 5:59 am
That is disappointing. But, thanks a lot for the help.
Users browsing this forum: No registered users and 106 guests
