CMake system build for reusing components
adesandr
Postby adesandr » Sat May 09, 2020 12:10 pm
I going to you because i'm having a hard time solving an issue with the CMakeList build system.
Basically I want to share various components between various projects, without copy my components in each projects.
My directories are structured as below (extra_components is as the same level than project1/ ... projectN) :
MyProjets/
|---project1/
|---|---main/
|---|---|--- filemain.c
|---|---|--- filemain.h
|---|---|--- CMakeList.txt
|---|---CMakeList.txt
|---projectN/
|...| same structure as project1
|...extra_components/
|...|... component1/
|...|... |... file1.c
|...|... |... file1.h
|---|----|--- CMakeList.txt
|...|... componentN/
|...|... |... fileN.c
|...|... |... fileN.h
MyProjects/project1/main/CMakeList.txt which need component1 is :
  1. idf_component_register(SRCS "filemain.c"
  2.                        INCLUDE_DIRS ""  "${PROJECT_DIR}/../extra_components/component1")
MyProjets/projet1/CMakeList.txt is :
  1. cmake_minimum_required(VERSION 3.5)
  2. set(EXTRA_COMPONENT_DIRS "${PROJECT_DIR}/../extra_components")
  3. include($ENV{IDF_PATH}/tools/cmake/project.cmake)
  4. project(project1)
unfortunately when i build project1, compilation works fine but component1 is not find by the linker, and is normal because when i check the components list and component path don't show any reference to component1.
I tryed to reference component1 using various CMake syntax like add_target_library, etc, with no success, component1 is never integrated neither in the components list nor the components path.
Thank you in advance for your help.
Regards.
ESP_igrr
Re: CMake system build for reusing components
Postby ESP_igrr » Sun May 10, 2020 9:57 am
Hi adesandr,
Instead of adding "${PROJECT_DIR}/../extra_components/component1" to the list of include directories in main/CMakeLists.txt, you need to add "component1" to the list of dependencies of the main component.
You can do this by adding REQUIRES component1 to the arguments of idf_component_register. If component A requires component B, then the build system will add public include paths of component B when compiling component A, and will also place component A before component B on the linker command line, ensuring that link-time dependencies are satisfied.
More about component requirements: https://docs.espressif.com/projects/esp ... quirements
adesandr
Postby adesandr » Sun May 10, 2020 3:43 pm
Hi ESP_igrr,
Many thank for your kind response.
I modified MyProject/project1/CMakeList.txt as follows :
  2. include($ENV{IDF_PATH}/tools/cmake/project.cmake)
  3. project(project1)
I modified MyProject/Project1/main/CMakeListe.txt as follows
  2.                        INCLUDE_DIRS "" "${PROJECT_DIR}/../Includes" "${PROJECT_DIR}/../extra_components/component1"
  3.                        REQUIRES component1)
when I launch idf.py reconfigure I obtain :
CMake Error at /home/adesandr/esp-idf/tools/cmake/build.cmake:185 (message):
Failed to resolve component 'component1
I tried also using in MyProject/Project1/main/CMakeListe.txt :
  3.                        REQUIRES path_to_component1/component1)
I obtain the same error message, using a "path_to_component" in absolute or in relative.
If I put my extra_components directorie, inside project1, renaming the directorie in "components", the build works great, but I need to copy my component in each projects and it is not the target.
My extra_components directorie is as the same level than project1, so I can't understand how the CMakeList Wrapper can resolve giving him only component1 with the REQUIRES directive ?
Thank you for your help.
Regards.
Users browsing this forum: Google [Bot] and 89 guests
