Can't get esp now and wifi to work together.
swedaniel8
Postby swedaniel8 » Wed Apr 29, 2020 1:54 pm
I have been trying to simply send data from the web(phone) to the "master" device and it shall send the value to the slaves. But for some reason which I can not figure out the data is send by the master but not recived by the slaves.
I got it to work once, but couple of days later it is not working.
Master code
#include <esp_now.h>
#include <WiFi.h>
const char* ssid = "ssid>";
const char* password ="pass";
//uint8_t broadcastAddress2[] = {0xCC,0x50,0xE3,0xBE,0xB5,0xD4};
uint8_t broadcastAddress[] = {0xCC,0x50,0xE3,0xBE,0x4C,0xAC};
WiFiServer server(80);
int myData;
  // Init Serial Monitor
  WiFi.mode(WIFI_AP_STA);
  Serial.print("Connecting to ::=> "); Serial.println(ssid);
  WiFi.begin(ssid, password);
      delay(500);
      Serial.println("Connecting to WiFi..");
  Serial.println("Success");
  Serial.print("IP address: ");
  server.begin();
  // register second peer
//  memcpy(peerInfo.peer_addr, broadcastAddress2, 6);
//  if (esp_now_add_peer(&peerInfo) != ESP_OK){
//    Serial.println("Failed to add peer");
//    return;
  esp_now_init();
  esp_now_register_send_cb(OnDataSent);
  esp_now_peer_info_t peerInfo;
  peerInfo.channel = 0;
  peerInfo.encrypt = false;
  // register first peer
  memcpy(peerInfo.peer_addr, &broadcastAddress, 6);
    return;
  pinMode(19, OUTPUT);
  pinMode(33, OUTPUT);
  delay(2000);
  esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
  if (result == ESP_OK) {
    Serial.println("Sent with success");
  else {
    Serial.println("Error sending the data");
  WiFiClient client = server.available();
  if(client) {
    String req = client.readStringUntil('\r');
    client.flush();
    if (req.indexOf("/master_relay19/on") !=-1)
    digitalWrite(19,1);
    else if (req.indexOf("/master_relay19/off") !=-1)
    digitalWrite(19,0);
    else if (req.indexOf("/master_relay33/on") !=-1)
    digitalWrite(33,1);
    else if (req.indexOf("/master_relay33/off") !=-1)
    digitalWrite(33,0);
    else if (req.indexOf("/slave_relay33/on") !=-1)
    myData = 1;
    else if (req.indexOf("/slave_relay33/off") !=-1)
    myData = 2;
    else if (req.indexOf("/slave_relay19/on") !=-1)
    myData = 3;
    else if (req.indexOf("/slave_relay19/off") !=-1)
    myData = 4;
    else if (req.indexOf("/lightswitch_relay19/on") !=-1)
    myData = 5;
    else if (req.indexOf("/lightswitch_relay19/off") !=-1)
    myData = 6;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  char macStr[18];
  Serial.print("Packet to: ");
  // Copies the sender mac address to a string
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
  Serial.print(macStr);
  Serial.print(" send status:\t");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
Slave code
#include <WiFi.h>
int myData;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
  memcpy(&myData, incomingData, sizeof(myData));
  Serial.print("Bytes received: ");
  Serial.println(myData);
  if (myData == 5)
    digitalWrite(19,1);
  else if (myData == 6)
    digitalWrite(19,0);
  // Initialize Serial Monitor
  pinMode(19,OUTPUT);
  // Init ESP-NOW
  if (esp_now_init() != ESP_OK) {
    Serial.println("Error initializing ESP-NOW");
    return;
  esp_now_register_recv_cb(OnDataRecv);
Serial.println(WiFi.macAddress());
delay(3000);
Users browsing this forum: No registered users and 88 guests
