dueros例程使用问题
lys23926635
dueros例程使用问题
Postby lys23926635 » Tue Apr 21, 2020 5:32 am
我使用Lyrat V4.3在跑Dueros例程时遇到如下问题,每次按下rec键时都提示wakeup_time_out超时,dueros_profile 已经更新,代码无修改,请问是什么原因呢?
关键log如下:
I (626172) AUDIO_ELEMENT: [OUT_iis] AEL_MSG_CMD_RESUME,state:1
I (626178) I2S_STREAM: AUDIO_STREAM_WRITER
I (626185) AUDIO_PIPELINE: Pipeline started
I (626189) AUDIO_ELEMENT: [resample] AEL_MSG_CMD_RESUME,state:1
I (626195) RSP_FILTER: sample rate of source data : 16000, channel of source data : 1, sample rate of destination data : 48000, channel of destination data : 2
I (626210) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_RUNNING
W (626504) FATFS_STREAM: No more data,ret:0
I (626504) AUDIO_ELEMENT: IN-[IN_file] AEL_IO_DONE,0
I (626834) AUDIO_ELEMENT: IN-[DEC_wav] AEL_IO_DONE,-2
I (626834) ESP_AUDIO_TASK: Received last pos: 29832 bytes
I (626911) REC_ENG: Wakeup time is out
I (627109) AUDIO_ELEMENT: IN-[resample] AEL_IO_DONE,-2
I (627159) AUDIO_ELEMENT: IN-[OUT_iis] AEL_IO_DONE,-2
I (627196) ESP_AUDIO_TASK: Received last time: 975 ms
I (627196) ESP_AUDIO_TASK: ESP_AUDIO status is AEL_STATUS_STATE_FINISHED
E (627199) REC_ENG: State FETCH_DATA, wakeup_time_out:1, vad_speech_on:0, vad_time_mode:0
W (627207) REC_ENG: State WAKEUP_END
I (627212) DUEROS: rec_engine_cb - REC_EVENT_WAKEUP_END
I (627218) REC_ENG: state idle
zfc212@163.com
Re: dueros例程使用问题
Postby zfc212@163.com » Fri May 15, 2020 1:52 am
我也碰到了,不知道咋回事
lys23926635
Re: dueros例程使用问题
Postby lys23926635 » Tue Jul 14, 2020 1:35 am
把提示音去掉就好了
