ESP32-WROOM-32D new and flashed?
ServerMax
Postby ServerMax » Thu Apr 16, 2020 4:32 pm
Hello
If i buy a new module, is it ready to use with arduino ide? Should it be flashed?
Cause i wanna switch from ESP32 Dev kit to the module with external USB-UART.
thank you
fasani
Contact:
Re: ESP32-WROOM-32D new and flashed?
Postby fasani » Fri Apr 17, 2020 5:41 am
Yes I think any ESP32 board will work with Arduino-framework
I highly recommend to use Platformio IDE instead of Arduino itself, since unlike Arduino it keeps the libraries for every project in their own folder and has dependency management using a config file called platformio.ini
The only one that still does not work using Arduino-framework is the new model ESP32S2. For that one I could only use ESP-IDF
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
ServerMax
Postby ServerMax » Fri Apr 17, 2020 11:56 am
Thank you.
I will try it.
ServerMax
Postby ServerMax » Tue Apr 21, 2020 2:02 pm
And one more question about this.
Which board should i choose from Arduino IDE (i haven't downloaded other yet)?
Actually i'm using the ESP32 Dev Module. But i'm still woring with the dev board. I think it is the same, but not sure.
Users browsing this forum: No registered users and 89 guests
