SCLK pulses not seen when using SPI on ESP32
goutham1995
Postby goutham1995 » Tue Apr 14, 2020 7:14 am
I am using the following code in my esp32 using arduino IDE for spi communication which is an example code -
#include <SPI.h>
static const int spiClk = 1000000; // 1 MHz
//uninitalised pointers to SPI objects
SPIClass * vspi = NULL;
SPIClass * hspi = NULL;
  //initialise two instances of the SPIClass attached to VSPI and HSPI respectively
  vspi = new SPIClass(VSPI);
  hspi = new SPIClass(HSPI);
  //clock miso mosi ss
  //initialise vspi with default pins
  //SCLK = 18, MISO = 19, MOSI = 23, SS = 5
  vspi->begin();
  //alternatively route through GPIO pins of your choice
  //hspi->begin(0, 2, 4, 33); //SCLK, MISO, MOSI, SS
  //initialise hspi with default pins
  //SCLK = 14, MISO = 12, MOSI = 13, SS = 15
  hspi->begin();
  //hspi->begin(25, 26, 27, 32); //SCLK, MISO, MOSI, SS
  //set up slave select pins as outputs as the Arduino API
  //doesn't handle automatically pulling SS low
  pinMode(5, OUTPUT); //VSPI SS
  pinMode(15, OUTPUT); //HSPI SS
// the loop function runs over and over again until power down or reset
  //use the SPI buses
  vspiCommand();
  hspiCommand();
  delay(100);
void vspiCommand() {
  byte data = 0b01010101; // junk data to illustrate usage
  //use it as you would the regular arduino SPI API
  vspi->beginTransaction(SPISettings(spiClk, MSBFIRST, SPI_MODE0));
  digitalWrite(5, LOW); //pull SS slow to prep other end for transfer
  vspi->transfer(data);
  delay(500);
  digitalWrite(5, HIGH); //pull ss high to signify end of data transfer
  vspi->endTransaction();
void hspiCommand() {
  byte stuff = 0b11001100;
  hspi->beginTransaction(SPISettings(spiClk, MSBFIRST, SPI_MODE0));
  digitalWrite(15, LOW);
  hspi->transfer(stuff);
  delay(500);
  digitalWrite(15, HIGH);
  hspi->endTransaction();
I am able to see the toggling of the SS pin, but the SCLK pin does not show any pulses on the oscilloscope. It is a constant low. Should the pulses be given from an external source? If so, what is the purpose of this line - static const int spiClk = 1000000; // 1 MHz?
fasani
Contact:
Re: SCLK pulses not seen when using SPI on ESP32
Postby fasani » Thu Apr 23, 2020 11:19 am
Interesting. But one question without using VSPI, if you use the default SPI pins from ESP32 (CLK -> 18 , MOSI -> 23)
Do you see the clock with your oscilloscope on that GPIO? Sadly I don't have now an oscilloscope handy otherwise I will test your code
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
Users browsing this forum: No registered users and 92 guests
