CMake building problems adding the cpp_utils component by N.Kolban
GabriSer87
Postby GabriSer87 » Sat Apr 11, 2020 4:57 pm
Hello everyone,
I'm trying to include the great (IMO) cpp_utils component by Neil Kolban into an ESP-IDF project. Initially I made a simple program using the GPIO.h interface provided by the Kolban's library in order to blink an LED. The program build and run without any sort of problems.
Then I moved forward activating the Bluetooth functionalities using the idf.py menuconfig tool and adding some src files (IndioClient.cpp and IndioClient.h) as an additional component, called indiotech.
The IndioClient.cpp file include the BLEDevice.h interface provided by the Kolban's library.
The structure of the program is the following:
- hello_world_ble/
             		- CMakeLists.txt
             		- sdkconfig
             		- components/
                        		   - cpp_utils/
                                        		 - CMakeLists.txt
                                        		 - many src files
                                         		 - many header files
                           		  - indiotech/
                                         		- CMakeLists.txt
                                        		 - IndioClient.cpp
                                         		 - IndioClient.h
                                         		 - IndioSensor.cpp
                                         		 - IndioSensor.h
             - main/
                           - main.cpp
                           - CMakeLists.txt
This is what I get running idf.py reconfigure:
C:\Users\gabri\Documents\esp_workspace\hello_world_ble>idf.py reconfigure
Checking Python dependencies...
Python requirements from C:\Users\gabri\esp-idf\requirements.txt are satisfied.
Executing action: reconfigure
Running cmake in directory c:\users\gabri\documents\esp_workspace\hello_world_ble\build
Executing "cmake -G Ninja -DPYTHON_DEPS_CHECKED=1 -DESP_PLATFORM=1 --warn-uninitialized -DCCACHE_ENABLE=0 c:\users\gabri\documents\esp_workspace\hello_world_ble"...
Warn about uninitialized values.
-- mconf-idf version mconf-v4.6.0.0-idf-20190628-win32
-- Project is not inside a git repository, or git repository has no commits; will not use 'git describe' to determine PROJECT_VER.
-- Project version: 1
-- Could NOT find Perl (missing: PERL_EXECUTABLE)
-- Adding linker script C:/Users/gabri/Documents/esp_workspace/hello_world_ble/build/esp-idf/esp32/esp32_out.ld
-- Adding linker script C:/Users/gabri/esp-idf/components/esp32/ld/esp32.project.ld.in
-- Adding linker script C:/Users/gabri/esp-idf/components/esp32/ld/esp32.peripherals.ld
-- Adding linker script C:/Users/gabri/esp-idf/components/esp_rom/esp32/ld/esp32.rom.ld
-- Adding linker script C:/Users/gabri/esp-idf/components/esp_rom/esp32/ld/esp32.rom.libgcc.ld
-- Adding linker script C:/Users/gabri/esp-idf/components/esp_rom/esp32/ld/esp32.rom.syscalls.ld
-- Adding linker script C:/Users/gabri/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-data.ld
-- Adding linker script C:/Users/gabri/esp-idf/components/esp_rom/esp32/ld/esp32.rom.newlib-funcs.ld
-- Components: app_trace app_update asio bootloader bootloader_support bt coap console cpp_utils cxx driver efuse esp-tls esp32 esp_adc_cal esp_common esp_eth esp_event esp_gdbstub esp_http_client esp_http_server esp_https_ota esp_https_server esp_local_ctrl esp_ringbuf esp_rom esp_websocket_client esp_wifi espcoredump esptool_py expat fatfs freemodbus freertos heap idf_test indiotech jsmn json libsodium log lwip main mbedtls mdns mqtt newlib nghttp nvs_flash openssl partition_table protobuf-c protocomm pthread sdmmc soc spi_flash spiffs tcp_transport tcpip_adapter ulp unity vfs wear_levelling wifi_provisioning wpa_supplicant xtensa
-- Component paths: C:/Users/gabri/esp-idf/components/app_trace C:/Users/gabri/esp-idf/components/app_update C:/Users/gabri/esp-idf/components/asio C:/Users/gabri/esp-idf/components/bootloader C:/Users/gabri/esp-idf/components/bootloader_support C:/Users/gabri/esp-idf/components/bt C:/Users/gabri/esp-idf/components/coap C:/Users/gabri/esp-idf/components/console C:/Users/gabri/Documents/esp_workspace/hello_world_ble/components/cpp_utils C:/Users/gabri/esp-idf/components/cxx C:/Users/gabri/esp-idf/components/driver C:/Users/gabri/esp-idf/components/efuse C:/Users/gabri/esp-idf/components/esp-tls C:/Users/gabri/esp-idf/components/esp32 C:/Users/gabri/esp-idf/components/esp_adc_cal C:/Users/gabri/esp-idf/components/esp_common C:/Users/gabri/esp-idf/components/esp_eth C:/Users/gabri/esp-idf/components/esp_event C:/Users/gabri/esp-idf/components/esp_gdbstub C:/Users/gabri/esp-idf/components/esp_http_client C:/Users/gabri/esp-idf/components/esp_http_server C:/Users/gabri/esp-idf/components/esp_https_ota C:/Users/gabri/esp-idf/components/esp_https_server C:/Users/gabri/esp-idf/components/esp_local_ctrl C:/Users/gabri/esp-idf/components/esp_ringbuf C:/Users/gabri/esp-idf/components/esp_rom C:/Users/gabri/esp-idf/components/esp_websocket_client C:/Users/gabri/esp-idf/components/esp_wifi C:/Users/gabri/esp-idf/components/espcoredump C:/Users/gabri/esp-idf/components/esptool_py C:/Users/gabri/esp-idf/components/expat C:/Users/gabri/esp-idf/components/fatfs C:/Users/gabri/esp-idf/components/freemodbus C:/Users/gabri/esp-idf/components/freertos C:/Users/gabri/esp-idf/components/heap C:/Users/gabri/esp-idf/components/idf_test C:/Users/gabri/Documents/esp_workspace/hello_world_ble/components/indiotech C:/Users/gabri/esp-idf/components/jsmn C:/Users/gabri/esp-idf/components/json C:/Users/gabri/esp-idf/components/libsodium C:/Users/gabri/esp-idf/components/log C:/Users/gabri/esp-idf/components/lwip C:/Users/gabri/Documents/esp_workspace/hello_world_ble/main C:/Users/gabri/esp-idf/components/mbedtls C:/Users/gabri/esp-idf/components/mdns C:/Users/gabri/esp-idf/components/mqtt C:/Users/gabri/esp-idf/components/newlib C:/Users/gabri/esp-idf/components/nghttp C:/Users/gabri/esp-idf/components/nvs_flash C:/Users/gabri/esp-idf/components/openssl C:/Users/gabri/esp-idf/components/partition_table C:/Users/gabri/esp-idf/components/protobuf-c C:/Users/gabri/esp-idf/components/protocomm C:/Users/gabri/esp-idf/components/pthread C:/Users/gabri/esp-idf/components/sdmmc C:/Users/gabri/esp-idf/components/soc C:/Users/gabri/esp-idf/components/spi_flash C:/Users/gabri/esp-idf/components/spiffs C:/Users/gabri/esp-idf/components/tcp_transport C:/Users/gabri/esp-idf/components/tcpip_adapter C:/Users/gabri/esp-idf/components/ulp C:/Users/gabri/esp-idf/components/unity C:/Users/gabri/esp-idf/components/vfs C:/Users/gabri/esp-idf/components/wear_levelling C:/Users/gabri/esp-idf/components/wifi_provisioning C:/Users/gabri/esp-idf/components/wpa_supplicant C:/Users/gabri/esp-idf/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/gabri/Documents/esp_workspace/hello_world_ble/build
Both cpp_utils and indiotech components are included and also the bt component from ESP-IDF is correctly included.
But when I try to build this project the compilation process fail with the following output:
C:\Users\gabri\Documents\esp_workspace\hello_world_ble>idf.py build
Executing action: all (aliases: build)
-- Found Git: C:/Program Files/Git/cmd/git.exe (found version "2.21.0.windows.1")
-- IDF_TARGET not set, using default target: esp32
-- The C compiler identification is GNU 8.2.0
-- The CXX compiler identification is GNU 8.2.0
-- Found assembler: C:/Users/gabri/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/gabri/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe
-- Check for working C compiler: C:/Users/gabri/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-gcc.exe -- works
-- Check for working CXX compiler: C:/Users/gabri/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe
-- Check for working CXX compiler: C:/Users/gabri/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/xtensa-esp32-elf-g++.exe -- works
-- Found PythonInterp: C:/Users/gabri/.espressif/python_env/idf4.0_py3.7_env/Scripts/python.exe (found version "3.7")
-- Configuring done
-- Generating done
Running ninja in directory c:\users\gabri\documents\esp_workspace\hello_world_ble\build
Executing "ninja all"...
[500/1149] Performing configure step for 'bootloader'
-- Project version: v4.0-dirty
-- Adding linker script C:/Users/gabri/esp-idf/components/bootloader/subproject/main/esp32.bootloader.ld
-- Adding linker script C:/Users/gabri/esp-idf/components/bootloader/subproject/main/esp32.bootloader.rom.ld
-- Components: bootloader bootloader_support efuse esp32 esp_common esp_rom esptool_py log main micro-ecc partition_table soc spi_flash xtensa
-- Component paths: C:/Users/gabri/esp-idf/components/bootloader C:/Users/gabri/esp-idf/components/bootloader_support C:/Users/gabri/esp-idf/components/efuse C:/Users/gabri/esp-idf/components/esp32 C:/Users/gabri/esp-idf/components/esp_common C:/Users/gabri/esp-idf/components/esp_rom C:/Users/gabri/esp-idf/components/esptool_py C:/Users/gabri/esp-idf/components/log C:/Users/gabri/esp-idf/components/bootloader/subproject/main C:/Users/gabri/esp-idf/components/bootloader/subproject/components/micro-ecc C:/Users/gabri/esp-idf/components/partition_table C:/Users/gabri/esp-idf/components/soc C:/Users/gabri/esp-idf/components/spi_flash C:/Users/gabri/esp-idf/components/xtensa
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/gabri/Documents/esp_workspace/hello_world_ble/build/bootloader
[539/1149] Performing build step for 'bootloader'
[1/62] Generating project_elf_src.c
[2/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/gpio_periph.c.obj
[3/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/cpu_util.c.obj
[4/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_init.c.obj
[5/62] Building C object CMakeFiles/bootloader.elf.dir/project_elf_src.c.obj
[6/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_clk_init.c.obj
[7/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_clk.c.obj
[8/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_periph.c.obj
[9/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_pm.c.obj
[10/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdio_slave_periph.c.obj
[11/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_time.c.obj
[12/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_sleep.c.obj
[13/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/rtc_wdt.c.obj
[14/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/memory_layout_utils.c.obj
[15/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/spi_periph.c.obj
[16/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_hal_iram.c.obj
[17/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/soc_memory_layout.c.obj
[18/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/lldesc.c.obj
[19/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/esp32/sdmmc_periph.c.obj
[20/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_hal.c.obj
[21/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/soc_include_legacy_warn.c.obj
[22/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_flash_hal.c.obj
[23/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_slave_hal_iram.c.obj
[24/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_flash_hal_iram.c.obj
[25/62] Building C object esp-idf/soc/CMakeFiles/__idf_soc.dir/src/hal/spi_slave_hal.c.obj
[26/62] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/trax.c.obj
[27/62] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/eri.c.obj
[28/62] Building ASM object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/debug_helpers_asm.S.obj
[29/62] Building C object esp-idf/xtensa/CMakeFiles/__idf_xtensa.dir/debug_helpers.c.obj
[30/62] Building C object esp-idf/log/CMakeFiles/__idf_log.dir/log.c.obj
[31/62] Building C object esp-idf/spi_flash/CMakeFiles/__idf_spi_flash.dir/spi_flash_rom_patch.c.obj
[32/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_random.c.obj
[33/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash.c.obj
[34/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_flash_config.c.obj
[35/62] Linking C static library esp-idf\log\liblog.a
[36/62] Building C object esp-idf/micro-ecc/CMakeFiles/__idf_micro-ecc.dir/micro-ecc/uECC.c.obj
[37/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_clock.c.obj
[38/62] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/esp32/esp_efuse_table.c.obj
[39/62] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_fields.c.obj
[40/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_common.c.obj
[41/62] Linking C static library esp-idf\xtensa\libxtensa.a
[42/62] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_api.c.obj
[43/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_encrypt.c.obj
[44/62] Building C object esp-idf/efuse/CMakeFiles/__idf_efuse.dir/src/esp_efuse_utility.c.obj
[45/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_utility.c.obj
[46/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp_image_format.c.obj
[47/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_partitions.c.obj
[48/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/bootloader_sha.c.obj
[49/62] Linking C static library esp-idf\soc\libsoc.a
[50/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/bootloader_init.c.obj
[51/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/flash_encrypt.c.obj
[52/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/flash_qio_mode.c.obj
[53/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/secure_boot_signatures.c.obj
[54/62] Building C object esp-idf/bootloader_support/CMakeFiles/__idf_bootloader_support.dir/src/esp32/secure_boot.c.obj
[55/62] Linking C static library esp-idf\micro-ecc\libmicro-ecc.a
[56/62] Building C object esp-idf/main/CMakeFiles/__idf_main.dir/bootloader_start.c.obj
[57/62] Linking C static library esp-idf\bootloader_support\libbootloader_support.a
[58/62] Linking C static library esp-idf\efuse\libefuse.a
[59/62] Linking C static library esp-idf\spi_flash\libspi_flash.a
[60/62] Linking C static library esp-idf\main\libmain.a
[61/62] Linking C executable bootloader.elf
[62/62] Generating binary image from built executable
esptool.py v2.8
Generated C:/Users/gabri/Documents/esp_workspace/hello_world_ble/build/bootloader/bootloader.bin
[1059/1149] Building CXX object esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLEAddress.cpp.obj
FAILED: esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLEAddress.cpp.obj
C:\Users\gabri\.espressif\tools\xtensa-esp32-elf\esp-2019r2-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe  -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -Iconfig -I../components/cpp_utils -IC:/Users/gabri/esp-idf/components/newlib/platform_include -IC:/Users/gabri/esp-idf/components/freertos/include -IC:/Users/gabri/esp-idf/components/heap/include -IC:/Users/gabri/esp-idf/components/log/include -IC:/Users/gabri/esp-idf/components/soc/esp32/include -IC:/Users/gabri/esp-idf/components/soc/include -IC:/Users/gabri/esp-idf/components/esp_rom/include -IC:/Users/gabri/esp-idf/components/esp_common/include -IC:/Users/gabri/esp-idf/components/xtensa/include -IC:/Users/gabri/esp-idf/components/xtensa/esp32/include -IC:/Users/gabri/esp-idf/components/esp32/include -IC:/Users/gabri/esp-idf/components/driver/include -IC:/Users/gabri/esp-idf/components/esp_ringbuf/include -IC:/Users/gabri/esp-idf/components/esp_event/include -IC:/Users/gabri/esp-idf/components/tcpip_adapter/include -IC:/Users/gabri/esp-idf/components/lwip/include/apps -IC:/Users/gabri/esp-idf/components/lwip/include/apps/sntp -IC:/Users/gabri/esp-idf/components/lwip/lwip/src/include -IC:/Users/gabri/esp-idf/components/lwip/port/esp32/include -IC:/Users/gabri/esp-idf/components/lwip/port/esp32/include/arch -IC:/Users/gabri/esp-idf/components/vfs/include -IC:/Users/gabri/esp-idf/components/esp_wifi/include -IC:/Users/gabri/esp-idf/components/esp_wifi/esp32/include -IC:/Users/gabri/esp-idf/components/esp_eth/include -IC:/Users/gabri/esp-idf/components/efuse/include -IC:/Users/gabri/esp-idf/components/efuse/esp32/include -IC:/Users/gabri/esp-idf/components/app_trace/include -IC:/Users/gabri/esp-idf/components/console -IC:/Users/gabri/esp-idf/components/fatfs/diskio -IC:/Users/gabri/esp-idf/components/fatfs/vfs -IC:/Users/gabri/esp-idf/components/fatfs/src -IC:/Users/gabri/esp-idf/components/wear_levelling/include -IC:/Users/gabri/esp-idf/components/spi_flash/include -IC:/Users/gabri/esp-idf/components/sdmmc/include -IC:/Users/gabri/esp-idf/components/json/cJSON -IC:/Users/gabri/esp-idf/components/mdns/include -IC:/Users/gabri/esp-idf/components/mbedtls/port/include -IC:/Users/gabri/esp-idf/components/mbedtls/mbedtls/include -IC:/Users/gabri/esp-idf/components/nvs_flash/include -mlongcalls -Wno-frame-address   -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -nostdlib -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu++11 -fexceptions -fno-rtti -D_GNU_SOURCE -DIDF_VER=\"v4.0-dirty\" -DGCC_NOT_5_2_0 -DESP_PLATFORM -MD -MT esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLEAddress.cpp.obj -MF esp-idf\cpp_utils\CMakeFiles\__idf_cpp_utils.dir\BLEAddress.cpp.obj.d -o esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLEAddress.cpp.obj -c ../components/cpp_utils/BLEAddress.cpp
In file included from ../components/cpp_utils/BLEAddress.cpp:10:
../components/cpp_utils/BLEAddress.h:12:10: fatal error: esp_gap_ble_api.h: No such file or directory
 #include <esp_gap_ble_api.h> // ESP32 BLE
compilation terminated.
[1062/1149] Building CXX object esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2904.cpp.obj
FAILED: esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2904.cpp.obj
C:\Users\gabri\.espressif\tools\xtensa-esp32-elf\esp-2019r2-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe  -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -Iconfig -I../components/cpp_utils -IC:/Users/gabri/esp-idf/components/newlib/platform_include -IC:/Users/gabri/esp-idf/components/freertos/include -IC:/Users/gabri/esp-idf/components/heap/include -IC:/Users/gabri/esp-idf/components/log/include -IC:/Users/gabri/esp-idf/components/soc/esp32/include -IC:/Users/gabri/esp-idf/components/soc/include -IC:/Users/gabri/esp-idf/components/esp_rom/include -IC:/Users/gabri/esp-idf/components/esp_common/include -IC:/Users/gabri/esp-idf/components/xtensa/include -IC:/Users/gabri/esp-idf/components/xtensa/esp32/include -IC:/Users/gabri/esp-idf/components/esp32/include -IC:/Users/gabri/esp-idf/components/driver/include -IC:/Users/gabri/esp-idf/components/esp_ringbuf/include -IC:/Users/gabri/esp-idf/components/esp_event/include -IC:/Users/gabri/esp-idf/components/tcpip_adapter/include -IC:/Users/gabri/esp-idf/components/lwip/include/apps -IC:/Users/gabri/esp-idf/components/lwip/include/apps/sntp -IC:/Users/gabri/esp-idf/components/lwip/lwip/src/include -IC:/Users/gabri/esp-idf/components/lwip/port/esp32/include -IC:/Users/gabri/esp-idf/components/lwip/port/esp32/include/arch -IC:/Users/gabri/esp-idf/components/vfs/include -IC:/Users/gabri/esp-idf/components/esp_wifi/include -IC:/Users/gabri/esp-idf/components/esp_wifi/esp32/include -IC:/Users/gabri/esp-idf/components/esp_eth/include -IC:/Users/gabri/esp-idf/components/efuse/include -IC:/Users/gabri/esp-idf/components/efuse/esp32/include -IC:/Users/gabri/esp-idf/components/app_trace/include -IC:/Users/gabri/esp-idf/components/console -IC:/Users/gabri/esp-idf/components/fatfs/diskio -IC:/Users/gabri/esp-idf/components/fatfs/vfs -IC:/Users/gabri/esp-idf/components/fatfs/src -IC:/Users/gabri/esp-idf/components/wear_levelling/include -IC:/Users/gabri/esp-idf/components/spi_flash/include -IC:/Users/gabri/esp-idf/components/sdmmc/include -IC:/Users/gabri/esp-idf/components/json/cJSON -IC:/Users/gabri/esp-idf/components/mdns/include -IC:/Users/gabri/esp-idf/components/mbedtls/port/include -IC:/Users/gabri/esp-idf/components/mbedtls/mbedtls/include -IC:/Users/gabri/esp-idf/components/nvs_flash/include -mlongcalls -Wno-frame-address   -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -nostdlib -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu++11 -fexceptions -fno-rtti -D_GNU_SOURCE -DIDF_VER=\"v4.0-dirty\" -DGCC_NOT_5_2_0 -DESP_PLATFORM -MD -MT esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2904.cpp.obj -MF esp-idf\cpp_utils\CMakeFiles\__idf_cpp_utils.dir\BLE2904.cpp.obj.d -o esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2904.cpp.obj -c ../components/cpp_utils/BLE2904.cpp
In file included from ../components/cpp_utils/BLEDescriptor.h:13,
                 from ../components/cpp_utils/BLE2904.h:13,
                 from ../components/cpp_utils/BLE2904.cpp:15:
../components/cpp_utils/BLEUUID.h:12:10: fatal error: esp_gatt_defs.h: No such file or directory
 #include <esp_gatt_defs.h>
[1063/1149] Building CXX object esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2902.cpp.obj
FAILED: esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2902.cpp.obj
C:\Users\gabri\.espressif\tools\xtensa-esp32-elf\esp-2019r2-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe  -DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\" -Iconfig -I../components/cpp_utils -IC:/Users/gabri/esp-idf/components/newlib/platform_include -IC:/Users/gabri/esp-idf/components/freertos/include -IC:/Users/gabri/esp-idf/components/heap/include -IC:/Users/gabri/esp-idf/components/log/include -IC:/Users/gabri/esp-idf/components/soc/esp32/include -IC:/Users/gabri/esp-idf/components/soc/include -IC:/Users/gabri/esp-idf/components/esp_rom/include -IC:/Users/gabri/esp-idf/components/esp_common/include -IC:/Users/gabri/esp-idf/components/xtensa/include -IC:/Users/gabri/esp-idf/components/xtensa/esp32/include -IC:/Users/gabri/esp-idf/components/esp32/include -IC:/Users/gabri/esp-idf/components/driver/include -IC:/Users/gabri/esp-idf/components/esp_ringbuf/include -IC:/Users/gabri/esp-idf/components/esp_event/include -IC:/Users/gabri/esp-idf/components/tcpip_adapter/include -IC:/Users/gabri/esp-idf/components/lwip/include/apps -IC:/Users/gabri/esp-idf/components/lwip/include/apps/sntp -IC:/Users/gabri/esp-idf/components/lwip/lwip/src/include -IC:/Users/gabri/esp-idf/components/lwip/port/esp32/include -IC:/Users/gabri/esp-idf/components/lwip/port/esp32/include/arch -IC:/Users/gabri/esp-idf/components/vfs/include -IC:/Users/gabri/esp-idf/components/esp_wifi/include -IC:/Users/gabri/esp-idf/components/esp_wifi/esp32/include -IC:/Users/gabri/esp-idf/components/esp_eth/include -IC:/Users/gabri/esp-idf/components/efuse/include -IC:/Users/gabri/esp-idf/components/efuse/esp32/include -IC:/Users/gabri/esp-idf/components/app_trace/include -IC:/Users/gabri/esp-idf/components/console -IC:/Users/gabri/esp-idf/components/fatfs/diskio -IC:/Users/gabri/esp-idf/components/fatfs/vfs -IC:/Users/gabri/esp-idf/components/fatfs/src -IC:/Users/gabri/esp-idf/components/wear_levelling/include -IC:/Users/gabri/esp-idf/components/spi_flash/include -IC:/Users/gabri/esp-idf/components/sdmmc/include -IC:/Users/gabri/esp-idf/components/json/cJSON -IC:/Users/gabri/esp-idf/components/mdns/include -IC:/Users/gabri/esp-idf/components/mbedtls/port/include -IC:/Users/gabri/esp-idf/components/mbedtls/mbedtls/include -IC:/Users/gabri/esp-idf/components/nvs_flash/include -mlongcalls -Wno-frame-address   -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -nostdlib -Wall -Werror=all -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wextra -Wno-unused-parameter -Wno-sign-compare -ggdb -Og -std=gnu++11 -fexceptions -fno-rtti -D_GNU_SOURCE -DIDF_VER=\"v4.0-dirty\" -DGCC_NOT_5_2_0 -DESP_PLATFORM -MD -MT esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2902.cpp.obj -MF esp-idf\cpp_utils\CMakeFiles\__idf_cpp_utils.dir\BLE2902.cpp.obj.d -o esp-idf/cpp_utils/CMakeFiles/__idf_cpp_utils.dir/BLE2902.cpp.obj -c ../components/cpp_utils/BLE2902.cpp
                 from ../components/cpp_utils/BLE2902.h:13,
                 from ../components/cpp_utils/BLE2902.cpp:15:
[1064/1149] Building CXX object esp-idf/main/CMakeFiles/__idf_main.dir/main.cpp.obj
ninja failed with exit code 1
The problem seems related to the missing reference to the esp_gatt_defs.h file provided by the ESP-IDF.
Can you help me in interpreting the output of the compiler and fixing the broken dependencies?
Any help will be appreciated.
Thanks,
Gabriele (Italy)
wegunterjr
Re: CMake building problems adding the cpp_utils component by N.Kolban
Postby wegunterjr » Tue May 05, 2020 11:41 pm
did you ever get a response? I am having a similar problem...
wirvine90
Postby wirvine90 » Wed May 06, 2020 5:27 pm
I had this same issue in the past. This was about 6 months ago but I believe I needed to activate the BT Configuration in MenuConfig.
Component Config -> Bluetooth.
ESP_Angus
Postby ESP_Angus » Thu May 07, 2020 4:02 am
As well as BT configuration setting, in the CMake build system, components need to declare which other components they require.
For source files in the cpp_utils component to be able to include headers from "bt" component, they will need to declare this requirement in the cpp_utils/CMakeLists.txt file.
For a full explanation, see the IDF docs here:
https://docs.espressif.com/projects/esp ... quirements
wegunterjr
Postby wegunterjr » Tue Jun 23, 2020 3:53 am
so I added "bt" to the default CMakeLists.txt that was in the NKolban Repo....
Is this the only place that it is needed, or are you suggesting I need to add a requirement for including headers?
# Edit following two lines to set component requirements (see docs)
set(COMPONENT_REQUIRES
  "console"
  "fatfs"
  "json"
  "mdns"
  "nvs_flash"
  "bt"
set(COMPONENT_PRIV_REQUIRES bt )
file(GLOB COMPONENT_SRCS
  LIST_DIRECTORIES false
  "*.h"
  "*.cpp"
  "*.c"
  "*.S"
set(COMPONENT_ADD_INCLUDEDIRS ".")
register_component()
ESP_Angus
Postby ESP_Angus » Wed Jun 24, 2020 4:22 am
Doing this will allow this component's source files and headers to include headers defined in the "bt" component. You don't have to add anything else in order to use headers in "bt" (note that Bluetooth also needs to be enabled in the project configuration.)
Does the component build now? If yes, this is all you need to do. If no, might be that some other component requirement needs to be added as well.
AlexL2
Postby AlexL2 » Tue Feb 21, 2023 6:11 am
Finally! I found how to solve this build issue with "missing" Bluetooth headers.
Thanks a lot!
Users browsing this forum: Baidu [Spider] and 108 guests
