ESP32 prints some weird characters on i2c lcd using AsyncWebServer
gbaranski
Postby gbaranski » Thu Apr 09, 2020 4:20 pm
Hi, I use github.com/me-no-dev/ESPAsyncWebServer library for WiFi, SSD1306 from Adafruit for lcd, I coded something like this, on request "/setAlarm" ESP prints on LCD string "testing", but that prints me weird characters, code lloks like that, calling the same function from any different class works, only doesnt work if called from asynwebserver library
  1. void ManageWifi::setupServerHandling() {
  2.     server.on("/getTimeData", HTTP_GET, [] (AsyncWebServerRequest *request) {
  3.         request->send(200, "text/plain", R"({"currentTime":")" + wifiTimeManager.getTime() + "\"}");
  4.         Serial.print("received/get");
  5.     });
  6.     server.on("/setAlarm", HTTP_GET, [](AsyncWebServerRequest * request) {
  7.         if(request->hasParam("time")) {
  8.             AsyncWebParameter* p = request->getParam("time");
  9.             Serial.printf("Received %s with value %s from IP: \n", p->name().c_str(), p->value().c_str());
  10.             Serial.println(request->client()->remoteIP());
  11.             request->send(200, "text/plain", "OK");
  12.             wifiTimeManager.saveAlarmTime(String(p->value()));
  13.             String outputMsg = "New request!\n Time: " + String(p->value()) + "\n IP: " + request->client()->remoteIP().toString();
  14.
  15.             lcdManager.printTextLcd("testing", 1);
  16.         }
  17.     });
  18.     server.onNotFound(notFound);
  19.     server.begin();
  20. }
I tried using xTaskCreate but that gave me same error.
  1. void ManageLcd::printTextLcd(String lcdText, int fontSize){
  2.     clearLcd();
  3.     display.setTextSize(fontSize);
  4.     display.print(lcdText);
  5.     display.display();
  6.     delay(1000);
  7. }
  8.
  9.
  10.
  11. void ManageLcd::clearLcd() {
  12.     display.setTextColor(WHITE);
  13.     display.setCursor(10, 0);
  14.     display.clearDisplay();
  15.
  16.     display.display();
  17. }
Screenshot 2020-04-09 at 18.19.45.png (218.64 KiB) Viewed 6390 times
that shows how it looks like for me
ESP_Me-no-dev
Re: ESP32 prints some weird characters on i2c lcd using AsyncWebServer
Postby ESP_Me-no-dev » Fri Apr 10, 2020 6:26 am
You are not sending a response to the request in the alarm handler :) You must request->send(response) in every handler.
gbaranski
Postby gbaranski » Fri Apr 10, 2020 9:39 am
I do at line 11
ESP_Sprite
Postby ESP_Sprite » Sat Apr 11, 2020 8:20 am
Moved to the Arduino subforum.
Users browsing this forum: No registered users and 55 guests
