interrupt timer not work with library
albi.so
Postby albi.so » Wed Apr 01, 2020 9:59 pm
Hello everyone,
I want to put this code, that i used for generate a precise interrupt into a library:
hw_timer_t * timer0 = NULL;
portMUX_TYPE timerMux0 = portMUX_INITIALIZER_UNLOCKED;
void IRAM_ATTR onTimer0(){
  portENTER_CRITICAL_ISR(&timerMux0);
  //Code
  portEXIT_CRITICAL_ISR(&timerMux0);
  timer0 = timerBegin(0, 80, true);
  timerAttachInterrupt(timer0, &onTimer0, true);
  timerAlarmWrite(timer0, 2000000, true);
  timerAlarmEnable(timer0); // enable
When compiling i get an error related to the void IRAM_ATTR onTimer0() (line timerAttachInterrupt(timer0, &onTimer0... )
Does anybody know how to implement it ?
I hope to have explain it well, Many thanks
ESP_Sprite
Re: interrupt timer not work with library
Postby ESP_Sprite » Thu Apr 02, 2020 8:14 am
It would help if you were to post the actual error...
albi.so
Postby albi.so » Thu Apr 02, 2020 1:18 pm
Of course! for be more precise i posted also the:
.h file
#ifndef int_lib
#define int_lib
#include "Arduino.h"
class InterruptLibrary
  public:
    void interrupt_setup();
    void IRAM_ATTR onTimer0();
#endif
.cpp file
#include "int_lib.h"
void InterruptLibrary::interrupt_setup() {
  timer0 = timerBegin(0, 40, true);
  timerAlarmWrite(timer0, 100, true);
void IRAM_ATTR InterruptLibrary::onTimer0() {
  //Critical Code here
  //code
And i got this error:
int_lib.cpp:5:33: error: ISO C++ forbids taking the address of an unqualified or parenthesized non-static member function to form a pointer to member function. Say '&InterruptLibrary::onTimer0' [-fpermissive]
int_lib.cpp:5:47: error: cannot convert 'void (InterruptLibrary::*)()' to 'void (*)()' for argument '2' to 'void timerAttachInterrupt(hw_timer_t*, void (*)(), bool)'
exit status 1
ESP_Sprite
Postby ESP_Sprite » Thu Apr 02, 2020 1:36 pm
The IRAM_ATTR has very little to do with this. Your basic problem is that you cannot directly use an object method as a callback, as the information wrt *which* object the function is called on is lost. The solution for this would be to work around the issue by passing the object in the argument to the interrupt callback. You then declare the interrupt callback as a static function that calls the *actual* callback on the object. However, on the Arduino timer code this is impossible as the timerAttachInterrupt doesn't provide for an argument to pass to the ISR.
The alternative would be to make InterruptLibrary into a singleton, and then use a static function to call the actual function on that singleton. As there is no need for an interrupt handler argument, this would work.
(PS: In general, your OO setup is a little bit weird... a library usually isn't encapsulated in an object. You'd encapsulate something more physical, like a OneshotTimer or something, in an object.)
albi.so
Postby albi.so » Thu Apr 02, 2020 2:34 pm
Thanks for the answer,
could you please provide an example ?
albi.so
SOLVED: interrupt timer not work with library
Postby albi.so » Tue Apr 07, 2020 9:17 am
SOLVED: i manage to not use class and everithing work fine. Thanks
Users browsing this forum: No registered users and 79 guests
