ESP32 Task
KrisRevi
ESP32 Task
Postby KrisRevi » Sun Mar 29, 2020 12:34 pm
i found this -> https://learn.sparkfun.com/tutorials/li ... isplay/all and i uploaded it to my ESP32 and it worked! great... now when i also put in my code for controlling my LED's and put that inside the void loop() the spotify script stops going / working!
the sparkfun script uses Task:
xTaskCreatePinnedToCore(
             Task1code, /* Task function. */
             "Task1",   /* name of task. */
             10000,     /* Stack size of task */
             NULL,      /* parameter of the task */
             0,         /* priority of the task */
             &Task1,    /* Task handle to keep track of created task */
             0);        /* pin task to core 0 */
i've never worked with Tasks on an ESP32 "TaskCreatePinnedToCore" how can this be fixed to run with my code?
username
Re: ESP32 Task
Postby username » Sun Mar 29, 2020 6:51 pm
I would guess that It's probably because loop() has a higher priority than task1.
Task1 has a priority of 0, which is as low as you can go. Thus it will get serviced last if other tasks are consuming CPU resources.
mrburnette
Re: ESP32 Task
Postby mrburnette » Sun Mar 29, 2020 11:16 pm
I have a forum post that hopefully explains the dualcore programming a bit:
https://www.hackster.io/rayburne/esp32- ... res-8dd948
Ray
Users browsing this forum: No registered users and 85 guests
