I2C - Using both Ports - First Transaction fails
kb3523
Postby kb3523 » Sat Mar 21, 2020 4:15 pm
Dear ESP community,
If the i2c driver is 'installed twice', the first transaction of the first initialized port fails. Afterwards the communication happens without any error on both ports.
Am I initializing both ports correctly? Is there anything else I could consider?
My current ESP-IDF Version is: v4.0-dev-1443
Thank you all in advance
I can reproduce it with the following steps, its enough to have only one i2c device connected to the first initialized port to test it:
#define I2C_DISTRIBUTED I2C_NUM_0
#define I2C_LOCAL       I2C_NUM_1
#define TEST_DEV_ADDR 0x20
esp_err_t i2c_master_init( i2c_port_t port );
int8_t bus_checkForACK(i2c_port_t port, uint8_t dev_addr);
void test_this_it_fails()
    i2c_master_init(I2C_LOCAL);
    i2c_master_init(I2C_DISTRIBUTED);
    while ( bus_checkForACK(I2C_LOCAL, 0x20 ) != ESP_OK )
            printf("First Transaction on First initialized bus failed! \n ");
    i2c_cmd_handle_t cmd_link = i2c_cmd_link_create();
    i2c_master_start(cmd_link);
    i2c_master_write_byte(cmd_link, (dev_addr << 1) | I2C_MASTER_WRITE, true);
    esp_err_t ret = i2c_master_cmd_begin(port, cmd_link, pdMS_TO_TICKS(1000));
    i2c_cmd_link_delete(cmd_link);
    return (int8_t)ret;
    i2c_config_t conf;
    if ( I2C_DISTRIBUTED )
        conf.mode = I2C_MODE_MASTER;
        conf.sda_io_num = GPIO_I2C_DIST_SDA;
        conf.scl_io_num = GPIO_I2C_DIST_SCL;
        conf.sda_pullup_en = GPIO_PULLUP_ENABLE;
        conf.scl_pullup_en = GPIO_PULLUP_ENABLE;
        conf.master.clk_speed = I2C_START_FREQ;
    else if ( I2C_LOCAL )
        conf.sda_io_num = GPIO_I2C_LOCAL_SDA;
        conf.scl_io_num = GPIO_I2C_LOCAL_SCL;
        conf.sda_pullup_en = GPIO_PULLUP_DISABLE;
        conf.scl_pullup_en = GPIO_PULLUP_DISABLE;
        conf.master.clk_speed = 1000000;
    else
        printf("I2C Invalid Config! \n");
        return 0xFF;
    if ( i2c_param_config(port, &conf) != ESP_OK )
        return 0xFF;
    return i2c_driver_install(port, conf.mode,
                              I2C_MASTER_RX_BUF_DISABLE,
                              I2C_MASTER_TX_BUF_DISABLE, ESP_INTR_FLAG_IRAM);
vonnieda
Re: I2C - Using both Ports - First Transaction fails
Postby vonnieda » Sat Mar 21, 2020 7:00 pm
Dear ESP community,
    return (int8_t)ret;
    i2c_config_t conf;
    else
        return 0xFF;
        return 0xFF;
You have an error in your code that is likely causing the issue.
Should be
 if (port == I2C_DISTRIBUTED)
And likewise for the next conditional.
Jason
kb3523
Postby kb3523 » Sat Mar 21, 2020 9:06 pm
Lol. This is so obvious, I dont know how I could not notice this.. :D
Maybe I should stop working for today :) Thank you, please consider thes topic closed. Is there an option to close the topic with the resolution: "Used did not have eyes to read his own code, others had.." ;)
Users browsing this forum: No registered users and 110 guests
