ArduinoOTA and WIFI_AP_STA mode -- upload only works on one interface
Eyer1951
Postby Eyer1951 » Sun Mar 15, 2020 9:31 pm
I have an ESP32 operating in AP-STA mode, with ArduinoOTA working. However, the upload only succeeds if my development machine (Windows) is connected to the ESP32's AP. It fails if the dev machine is connected to the same AP that the ESP is connected to as a STA.
I would like to understand why, and can this behavior be changed so I can upload via the ESP's STA interface instead?
Example sketch below. Details:
* the ESP32 connects to an AP called "Tumbo" and also acts as an AP with SSID "OTA"
* the ESP32 has a fixed IP address 192.168.4.106 for STA mode
When dev machine is connected to SSID "OTA" I can ping ESP32:
C:\ping 192.168.4.1
Pinging 192.168.4.1 with 32 bytes of data:
Reply from 192.168.4.1: bytes=32 time=4ms TTL=255
Upload succeeds:
espota.exe -r -i 192.168.4.1 -f firmware.bin -d -p 3232
11:24:00 [DEBUG]: Options: {'timeout': 10, 'esp_ip': '192.168.4.1', 'host_port': 41784, 'image': 'firmware.bin', 'host_ip': '0.0.0.0', 'auth': '', 'esp_port': 3232, 'spiffs': False, 'debug': True, 'progress': True}
11:24:00 [INFO]: Starting on 0.0.0.0:41784
11:24:00 [INFO]: Upload size: 748336
Sending invitation to 192.168.4.1
11:24:00 [INFO]: Waiting for device...
Uploading: [============================================================] 100% Done...
11:24:15 [INFO]: Waiting for result...
11:24:16 [INFO]: Result: OK
11:24:16 [INFO]: Success
The output from the ESP32:
OTA 1.0.2
Initialising Wifi...
Ready
IP address: 192.168.4.106
dhcps: send_offer>>udp_sendto result 0
Start updating sketch
Progress: 100%
End
When dev machine is connected to SSID "Tumbo" ping succeeds:
C:\ping 192.168.4.106
Pinging 192.168.4.106 with 32 bytes of data:
Reply from 192.168.4.106: bytes=32 time=416ms TTL=255
But upload fails:
espota.exe -r -i 192.168.4.106 -f firmware.bin -d -p 3232
11:26:12 [DEBUG]: Options: {'timeout': 10, 'esp_ip': '192.168.4.106', 'host_port': 48555, 'image': 'firmware.bin', 'host_ip': '0.0.0.0', 'auth': '', 'esp_port': 3232, 'spiffs': False, 'debug': True, 'progress': True}
11:26:12 [INFO]: Starting on 0.0.0.0:48555
11:26:12 [INFO]: Upload size: 748336
Sending invitation to 192.168.4.106 ..........
11:27:52 [ERROR]: No response from the ESP
Output from ESP32:
OTA 1.0.2
Ready
[E][WiFiUdp.cpp:183] endPacket(): could not send data: 5
Progress: 0%
The whole sketch is here:
#include <ArduinoOTA.h>
#include <WiFi.h>
char version[] = "OTA 1.0.2";
#define WIFI_SSID "Tumbo"
#define WIFI_PASSWORD "admin"
#define AP_SSID "OTA"
#define AP_PASS "admin"
IPAddress local_IP(192, 168, 4, 106);
IPAddress gateway(192, 168, 4, 1);
IPAddress subnet(255, 255, 255, 0);
    Serial.print("\n\n\");
    Serial.print(version);  // Yellow text
    Serial.println();
    if (WiFi.SSID() != WIFI_SSID) {
        Serial.println(F("Initialising Wifi..."));
        WiFi.mode(WIFI_AP_STA);
        WiFi.softAP(AP_SSID, AP_PASS, 1, 1, 10);  // channel = 1, hidden = true, 10 max
        WiFi.config(local_IP, gateway, subnet);
        WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
        WiFi.persistent(true);
        WiFi.setAutoConnect(true);
        WiFi.setAutoReconnect(true);
    delay(2000);
    while (WiFi.waitForConnectResult() != WL_CONNECTED) {
        Serial.println("Connection Failed! Rebooting...");
        delay(2000);
        ESP.restart();
    ArduinoOTA
        .onStart([]() {
            String type;
            if (ArduinoOTA.getCommand() == U_FLASH)
                type = "sketch";
            else  // U_SPIFFS
                type = "filesystem";
            Serial.println("Start updating " + type);
        .onEnd([]() { Serial.println("\nEnd"); })
        .onProgress([](unsigned int progress, unsigned int total) {
            Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
        .onError([](ota_error_t error) {
            Serial.printf("Error[%u]: ", error);
            if (error == OTA_AUTH_ERROR)
                Serial.println("Auth Failed");
            else if (error == OTA_BEGIN_ERROR)
                Serial.println("Begin Failed");
            else if (error == OTA_CONNECT_ERROR)
                Serial.println("Connect Failed");
            else if (error == OTA_RECEIVE_ERROR)
                Serial.println("Receive Failed");
            else if (error == OTA_END_ERROR)
                Serial.println("End Failed");
    ArduinoOTA.begin();
    Serial.println("Ready");
    Serial.print("IP address: ");
	ArduinoOTA.handle();
Users browsing this forum: No registered users and 54 guests
