crash using timers
danchik
crash using timers
Postby danchik » Thu Mar 16, 2017 8:26 am
Hi, i'm trying to run some code on timer, using FreeRTOS xTimerCreate and when timer expires, i get reset... This is on ESP32 (ESP32 thing dev board)
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "freertos/timers.h"
#include "freertos/task.h"
int xx=0;
void vCallbackFunction( TimerHandle_t xTimer ) {
    printf("in timer xx=%d\n", xx++);
    fflush(stdout);
void app_main()
    int myTimerID = 1;
    TimerHandle_t tm = xTimerCreate("refresh", 3000/portTICK_PERIOD_MS, pdTRUE, (void*)&myTimerID, vCallbackFunction);
    BaseType_t res = xTimerStart(tm,0);
    if(tm && res==pdPASS) {
        printf("timer created\n");
        printf("faled making timer\n");
    fflush(stdout);
    for(;;) { // also, can I let app_main exit, and expect timer keep expiring to run code in vCallbackFunction, or start new task in vCallbackFunction date app_main was exited
        vTaskDelay(100);
        printf(".");
        fflush(stdout);
if I exit vCallbackFunction quicker (without doing printfs just increment xx seems to work), but otherwise it fails with either Stack overflow or some other Guru panicked error (ex errors I get:
Guru Meditation Error of type InstrFetchProhibited occurred on core 0. Exception was unhanded.
or
***ERROR*** A stack overflow in task Tmr Svc has been detected.
abort() was called at PC 0x400853b0
Guru Meditation Error: Core 0 panic'ed (abort)
or is it that some things are just not available form callbacks like printf and fflush ?
or is it limited to how long I can remain in the callback before returning (If I start a task inside the callback instead, and do all the printing in that task it seems to be fine)?
Thank you
ESP_Angus
Re: crash using timers
Postby ESP_Angus » Thu Mar 16, 2017 9:23 am
The default stack size for the timer task is quite small, so performing a printf() overflows it.
There's a permanent fix for this coming soon, but in the meantime you can edit FreeRTOSConfig.h and increase the timer task stack size, there. 2048 bytes should be enough.
danchik
Postby danchik » Thu Mar 16, 2017 6:55 pm
Interesting, that was it... I saw this issue mentioned before while looking around, but since it's been a few month since that post I just assumed it was already fixed :)
Thank you
snahmad75
Postby snahmad75 » Wed Apr 10, 2019 9:46 am
Related question is if crash/exception happens during my delete and I did not execute
It gets restart silently.
and esp_restart() does not executed. Does it have impact on OTA. does OTA will fails.
JainamShah
Postby JainamShah » Thu Aug 19, 2021 11:34 am
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
int xx=0;
    fflush(stdout);
void app_main()
    int myTimerID = 1;
    fflush(stdout);
        vTaskDelay(100);
        printf(".");
        fflush(stdout);
or
Thank you
I am experiencing same problem.. I already set the timer stack size to 2100. For your reference I am using 4 timers in my project...
Some time at the time of timer_callback I am getting this error.
Backtrace:0x4008971b:0x3ffbcdc0 0x40089eed:0x3ffbcde0 0x4008d6b1:0x3ffbce00 0x4008bad5:0x3ffbce80 0x40089fe4:0x3ffbcea0 0x40089f96:0x00011214 |<-CORRUPTED
0x4008971b: panic_abort at H:/Jainam/components/esp_system/panic.c:356
0x40089eed: esp_system_abort at H:/Jainam/components/esp_system/system_api.c:112
0x4008d6b1: vApplicationStackOverflowHook at H:/Jainam/components/freertos/port/xtensa/port.c:489
0x4008bad5: vTaskSwitchContext at H:/Jainam/components/freertos/tasks.c:3290
0x40089fe4: _frxt_dispatch at H:/Jainam/components/freertos/port/xtensa/portasm.S:432
0x40089f96: _frxt_int_exit at H:/Jainam/components/freertos/port/xtensa/portasm.S:231
ELF file SHA256: 27de3df566a2f290
Rebooting...
mbratch
Postby mbratch » Thu Aug 19, 2021 1:31 pm
You can use `ESP_LOGI(...)` instead of `printf` and it uses less stack and it may work. `ESP_LOGI(...)` accepts format string.
DrMickeyLauer
Postby DrMickeyLauer » Fri Mar 08, 2024 5:43 pm
Resurrecting an old thread, but I just stumbled over this... has this fix been applied yet or do I still need to edit the FreeRTOSConfig header?
ESP_Sprite
Postby ESP_Sprite » Sat Mar 09, 2024 2:55 am
You can adjust the stack size in menuconfig now, item FREERTOS_TIMER_TASK_STACK_DEPTH.
DrMickeyLauer
Postby DrMickeyLauer » Sat Mar 09, 2024 12:51 pm
Excellent, thanks. I stumbled over this already, but I think it's good for documenting, in case someone else finds this thread.
Users browsing this forum: Google [Bot] and 67 guests
