HTTP Communication with Server
der_smu
Postby der_smu » Thu Mar 05, 2020 8:46 am
I want to build a two way communication between an ESP32 and a (Python) server.
The ESP32 shall send a first GET request to the server and according to the server's response call different POST or GET methods.
For the sake of simplicity, I would like to use HTTPclient.h.
  HTTPClient http;
  http.begin("http://xx.xx.x.xxx:5000/");
  int httpCode = http.GET();
  if(httpCode > 0) {
    Serial.printf("[HTTP] GET... code: %d\n", httpCode);
    if(httpCode == HTTP_CODE_OK) {
      String payload = http.getString();
      Serial.println(payload);
  }else{
    Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
  http.end();
This code snippets works fine, but here I perform a simple GET on "http://xx.xx.x.xxx:5000/". What's the correct way to then perform a GET or POST on e.g. "http://xx.xx.x.xxx:5000/one" or "http://xx.xx.x.xxx:5000/two"?
Do I have to end my HTTPClient and start a new connection with http.begin():
  HTTPClient http;
  http.begin("http://10.42.0.191:5000/");
  if(httpCode > 0) {
      http.end();
      http.begin("http://10.42.0.191:5000/one");
      http.end();
  }else{
  http.end();
  delay(500);
This does not look right for me, because - as I understand it - I want to reuse the same connection and not build up a new connection.
Thanks for your help!
Users browsing this forum: Google [Bot] and 50 guests
