ledc doesn't work after restart or deep sleep wakeup
Auxal3000
Postby Auxal3000 » Thu Feb 27, 2020 2:52 am
Hello
I'm using a ESP32 CAM that has a Led-flash included. I initialize the led in the program and it works ok. But if I call ESP.restart() or after a sleep wake up and the ledc is always of.
I don't know what to do.
Thanks for any help
Auxal3000
Re: ledc doesn't work after restart or deep sleep wakeup
Postby Auxal3000 » Thu Feb 27, 2020 10:51 am
I forgot to send the code:
Before setup:
#define ledFlash           4
into setup():
    ledcSetup(LEDC_CHANNEL_7, 12000, 9);
    ledcAttachPin(ledFlash, LEDC_CHANNEL_7);
    ledcWrite(LEDC_CHANNEL_7, 0);
into loop():
 ledcWrite(LEDC_CHANNEL_7, 50);
Auxal3000
Postby Auxal3000 » Tue Mar 03, 2020 11:07 pm
Solution found
I have seen that before to enter to sleep mode I used the instruction:
rtc_gpio_hold_en(GPIO_NUM_4);
This block this GPIO to prevent any changes in this pin.
After restart, the chip must execute the instruction:
rtc_gpio_hold_dis(GPIO_NUM_4);
to unblock it.
Users browsing this forum: Majestic-12 [Bot] and 57 guests
