ULP GPIO Control ESP32 DeepSleep
engrkhawaja
Postby engrkhawaja » Fri Feb 21, 2020 7:58 am
I am to control GPIO33 in ULP while ESP32 in Deep Sleep.
Issue is GPIO value changes while I am not changing the value. May be its reset or anything else.
Please guide me where is issue or give me simple program that I can control GPIO inside ULP while main processor Deep Sleep.
Main Program.
#include "esp32/ulp.h"
// include ulp header you will create
#include "ulp_main.h"
// must include ulptool helper functions also
#include "ulptool.h"
#include "driver/rtc_io.h"
#include "soc/rtc.h"
#include "soc/rtc_cntl_reg.h"
#include "soc/rtc_io_reg.h"
// Unlike the esp-idf always use these binary blob names
extern const uint8_t ulp_main_bin_start[] asm("_binary_ulp_main_bin_start");
extern const uint8_t ulp_main_bin_end[]   asm("_binary_ulp_main_bin_end");
static void init_run_ulp(uint32_t usec);
  delay(1000);
      esp_sleep_wakeup_cause_t cause = esp_sleep_get_wakeup_cause();
      switch(cause)
    case ESP_SLEEP_WAKEUP_EXT0 : Serial.printf("Wakeup caused by external signal using RTC_IO"); break;
    case ESP_SLEEP_WAKEUP_EXT1 : Serial.printf("Wakeup caused by external signal using RTC_CNTL"); break;
    case ESP_SLEEP_WAKEUP_TIMER : Serial.printf("Wakeup caused by timer"); break;
    case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.printf("Wakeup caused by touchpad"); break;
    case ESP_SLEEP_WAKEUP_ULP : Serial.printf("Wakeup caused by ULP program"); break;
    default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",cause); break;
    if (cause != ESP_SLEEP_WAKEUP_ULP) {
        Serial.printf("Not ULP wakeup, initializing ULP\n");
        init_run_ulp(5000*1000);
    Serial.printf("Entering deep sleep\n\n");
    start_ulp_program();
  // rtc_gpio_hold_en(GPIO_NUM_33);
    ESP_ERROR_CHECK( esp_sleep_enable_ulp_wakeup() );
    esp_deep_sleep_start();
int i;
static void init_run_ulp(uint32_t usec) {
   esp_err_t err = ulptool_load_binary(0, ulp_main_bin_start, (ulp_main_bin_end - ulp_main_bin_start) / sizeof(uint32_t));
    rtc_gpio_init(GPIO_NUM_33);
  rtc_gpio_set_direction(GPIO_NUM_33, RTC_GPIO_MODE_OUTPUT_ONLY);
   rtc_gpio_init(GPIO_NUM_32);
  rtc_gpio_set_direction(GPIO_NUM_32, RTC_GPIO_MODE_INPUT_ONLY);
  ulp_set_wakeup_period(0, usec);
 // err = ulp_run((&ulp_entry - RTC_SLOW_MEM) / sizeof(uint32_t));
  //if (err) Serial.println("Error Starting ULP Coprocessor");
Method to print the reason by which ESP32
has been awaken from sleep
void print_wakeup_reason(){
  esp_sleep_wakeup_cause_t wakeup_reason;
  wakeup_reason = esp_sleep_get_wakeup_cause();
  switch(wakeup_reason)
    default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
static void start_ulp_program()
    /* Reset sample counter */
    /* Start the program */
    esp_err_t err = ulp_run((&ulp_entry - RTC_SLOW_MEM) / sizeof(uint32_t));
    ESP_ERROR_CHECK(err);
ULP Code
#ifdef _ULPCC_
#include <ulp_c.h>
// global variable that the main processor can see
unsigned data1 = 0;
unsigned data2 = 0;
unsigned status1 = 0xFFFF;
unsigned i;
// all ulpcc programs have have this function
void entry() {
 wake ();
  halt();
#endif
Users browsing this forum: No registered users and 46 guests
