ESP-IDF V4.0, "undefined reference to" when working with multiple src files inside main
leofabri
Postby leofabri » Thu Feb 20, 2020 1:45 pm
I'm facing a problem when I try to compile an existing project which I'm basically trying to readapt to work with the new version of ESP-IDF V4.0 (the previous one was V3.3).
I noticed that the new development environment uses CMake in order to get the app running so, maybe my "inexperience" is the problem.
When I submit idf.py build flash I get these compilation errors:
app_main.cpp
FAILED: app.elf
cmd.exe /C "cd . && C:\Users\leofa\.espressif\tools\xtensa-esp32-elf\esp-2019r2-8.2.0\xtensa-esp32-elf\bin\xtensa-esp32-elf-g++.exe --sysroot=c:\development\esp/../xtensa-esp32-elf/xtensa-esp32-elf  -mlongcalls -Wno-frame-address  -nostdlib @CMakeFiles\app.elf.rsp  -o app.elf  && cd ."
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(app_main.cpp.obj):(.literal.app_main+0xc): undefined reference to `MyConfig'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(app_main.cpp.obj):(.literal.app_main+0x14): undefined reference to `MyCommandApp'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(app_main.cpp.obj):(.literal.app_main+0x24): undefined reference to `AddTaskToMap(void*)'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(app_main.cpp.obj):(.literal.app_main+0x28): undefined reference to `AppConfig::mount()'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(app_main.cpp.obj):(.literal.app_main+0x2c): undefined reference to `AppCommandApp::ConfigureLogging()'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(app_main.cpp.obj):(.literal.app_main+0x30): undefined reference to `Housekeeping::Housekeeping()'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: esp-idf/main/libmain.a(app_main.cpp.obj): in function `app_main':
C:\development\app\build/../main/app_main.cpp:56: undefined reference to `AddTaskToMap(void*)'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\development\app\build/../main/app_main.cpp:59: undefined reference to `AppConfig::mount()'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\development\app\build/../main/app_main.cpp:62: undefined reference to `AppCommandApp::ConfigureLogging()'
c:/users/leofa/.espressif/tools/xtensa-esp32-elf/esp-2019r2-8.2.0/xtensa-esp32-elf/bin/../lib/gcc/xtensa-esp32-elf/8.2.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\development\app\build/../main/app_main.cpp:68: undefined reference to `Housekeeping::Housekeeping()'
Unfortunately, I can't provide many details about the code in question, but basically I have this structure inside of main:
- CMakeLists.h
- components
- main
-- app_config.cpp
-- app_config.h
-- app_housekeeping.cpp
-- app_housekeeping.h
-- app_commands.cpp
-- app_commands.h
-- app_main.cpp
-- CMakeLists.txt
-- component.mk
CMakeLists.txt outside "main":
cmake_minimum_required(VERSION 3.5)
set(CMAKE_EXPORT_COMPILE_COMMANDS 1)
set(MDF_VER command bash -c "cd $ENV{MDF_PATH} && git describe --always --tags --dirty")
#CPPFLAGS := -D MDF_VER=\"$(MDF_VER)\"
set(EXTRA_COMPONENT_DIRS $ENV{MDF_PATH}/components $ENV{MDF_PATH}/components/third_party)
#set(EXTRA_COMPONENT_DIRS ${EXTRA_COMPONENT_DIRS} )
message(STATUS "EXTRA_COMPONENT_DIRS: ${EXTRA_COMPONENT_DIRS}")
set(CMAKE_SYSROOT $ENV{IDF_PATH}/../xtensa-esp32-elf/xtensa-esp32-elf)
project(app)
CMakeLists.txt inside "main":
idf_component_register(SRCS "app_main.cpp"
                    INCLUDE_DIRS ".")
Since the problem is at the very beginning of app_main.cpp (right when I call the external functions and classes) I do believe that the problem could be potentially related to CMakeLists.txt that isn't "seeing" those other files inside of main.
Some help would be very appreciated. Thank you in advance
boarchuz
Re: ESP-IDF V4.0, "undefined reference to" when working with multiple src files inside main
Postby boarchuz » Thu Feb 20, 2020 7:38 pm
You need to manually list your source files for main component:
idf_component_register(SRCS "app_main.cpp" "app_config.cpp" "app_housekeeping.cpp" ... etc
leofabri
Postby leofabri » Fri Feb 21, 2020 6:51 am
Thank you so much. I feel like I should have noticed that by myself but I didn't :lol:
Users browsing this forum: Bing [Bot] and 135 guests
