Problem starting gdb on VS code
felixcollins
Postby felixcollins » Wed Feb 19, 2020 10:17 pm
I get an error pop-up when trying to launch gdb.
It says " Failed to load MI Debugger: Error: write EPIPE"
I can run it in the terminal and connect to OCD successfully. It was working in the past so I'm wondering if an update broke it.
Anyone know what this means?
Cheers,
Felix
https://imgur.com/sMCeZrh
My launch.json:
	"version": "0.2.0",
	"configurations": [
			"name": "Launch Program",
			"type": "gdb",
			"request": "launch",
			"target": "./build/${workspaceFolderBasename}.elf",
			"cwd": "${workspaceFolder}",
			"gdbpath": "xtensa-esp32-elf-gdb",
			"autorun": [
				"target remote :3333",
				"mon reset halt",
				"flushregs",
				"thb app_main",
				"c"
			"preLaunchTask": "openocd",
			"postDebugTask": "killopenocd"
ESP_bignacio
Re: Problem starting gdb on VS code
Postby ESP_bignacio » Thu Feb 27, 2020 4:23 am
Hi there !
We are currently working on debug support in our extension for VS Code. In the meantime you can try use:
    "version": "0.2.0",
    "configurations": [
            "type": "cppdbg",
            "name": "ESP-IDF: Debug",
            "miDebuggerPath": "xtensa-esp32-elf-gdb",
            "program": "${workspaceFolder}/build/project-name.elf",
            "miDebuggerServerAddress": "localhost:3333",
            "args": [],
            "stopAtEntry": false,
            "environment": [],
            "externalConsole": true,
            "MIMode": "gdb"
and use .gdbinit in your project folder to set up gdb commands.
In our extension there is support to run openOCD from VS Code itself and others commands that might make development process easier.
Please give it a try in https://marketplace.visualstudio.com/it ... -extension
Users browsing this forum: No registered users and 20 guests
