Reading databurst by serial2
Henk van Beek
Postby Henk van Beek » Fri Feb 14, 2020 6:07 pm
I am using a ESP32 WROOM-32 with arduino IDE 1.8.10 with
I am trying to read a databurst from a MT382, an electrical energy meter.
It is real burst 325 chars of 9600 bps.
Basically it is very simple:
  1. #define RXD2 16
  2. #define TXD2 17
  3.
  4. #define Led_Catch 5
  5.
  6. {
  7.   pinMode(Led_Catch, OUTPUT);
  8.
  9.   // Setup serial ports
  10.   Serial.begin(115200);
  11.   Serial.println("Uart0 started 115200 bps.");
  12.
  13.   Serial2.begin(9600, SERIAL_8N1, 16, 17);
  14.   Serial.println("Uart2 started 9600 bps streight.");
  15. }
  16.
  17. void loop()
  18. {
  19.   char c;
  20.   while (Serial2.available() > 0)
  21.   {
  22.     digitalWrite(Led_Catch,HIGH);
  23.     c = Serial2.read();
  24.     Serial.print(c);
  25.     digitalWrite(Led_Catch,LOW);
  26.   }
  27.
  28.   delay(1000);
  29. }
Data does not come consecutive.
Connecting my logic analyzer:
one can see: Serial2.availble becomes active after about 100 chars.
trace 1: Incoming dat 9600 bps UART2
trace 2: Serial2.read activity
trace 3: Actual output 115200 bps UART0
Even when i send a few chars into UART2, Serial2.availble becomes active much later than the first incoming char.
idahowalker
Re: Reading databurst by serial2
Postby idahowalker » Sun Feb 16, 2020 2:20 pm
Sometimes using the Arduino way to get at the ESP32 functions does not work so well, as in the case of A:D conversions. That's when I turn to the ESP32 API https://docs.espressif.com/projects/esp ... /uart.html.
I have found that (Serial2.available() > 0) does not work as well as (Serial2.available() >= 1 ), you may, also, want to figure out of there are data start and data stop characters. Without some sort of start stop thingies, you will end up receiving data streams where you read data out of sequence.
An example of my use of serial:
void fReceiveSerial_LIDAR( void * parameters  )
  bool BeginSentence = false;
  char OneChar;
  char *str;
  str = (char *)ps_calloc(300, sizeof(char) ); // put str buffer into PSRAM
  // log_i("Free PSRAM before String: %d", ESP.getFreePsram());
  for ( ;; )
    EventBits_t xbit = xEventGroupWaitBits (eg, evtReceiveSerial_LIDAR, pdTRUE, pdTRUE, portMAX_DELAY);
    if ( LIDARSerial.available() >= 1 )
      while ( LIDARSerial.available() )
        OneChar = LIDARSerial.read();
        if ( BeginSentence )
          if ( OneChar == '>')
            if ( xSemaphoreTake( sema_ParseLIDAR_ReceivedSerial, xSemaphoreTicksToWait10 ) == pdTRUE )
               xQueueOverwrite( xQ_LIDAR_Display_INFO, ( void * ) &str );
              xEventGroupSetBits( eg, evtParseLIDAR_ReceivedSerial );
          strncat( str, &OneChar, 1 );
        else
          if ( OneChar == '<' )
            strcpy( str, ""); // clear string buffer
            BeginSentence = true; // found beginning of sentence
      } //  while ( LIDARSerial.available() )
    } //if ( LIDARSerial.available() >= 1 )
    xSemaphoreGive( sema_ReceiveSerial_LIDAR );
    //        log_i( "fReceiveSerial_LIDAR " );
    //        log_i(uxTaskGetStackHighWaterMark( NULL ));
  free(str);
  vTaskDelete( NULL );
} //void fParseSerial( void * parameters  )
Users browsing this forum: No registered users and 41 guests
