Hi all!
First THANK YOU for ESP32, IDF and ADF... Fantastic work!
I´ve this board (v2.2 - 2 mics - not 4), and managed to make it work OK from mics (stereo mode: left mic -> left speaker/earphone; right mic -> right speaker/earphone).
But no way to make LINEIN input work... never!
Changed audio_hal_codec_mode_t to AUDIO_HAL_CODEC_MODE_LINE_IN and nothing happens.
Any ideas?
Adrian
Help with Ai-Thinker ESP32-A1S Audio Kit
- shabtronic
Re: Help with Ai-Thinker ESP32-A1S Audio Kit
probably the mixer line-in routing isn't setup properly.
You'll need to read the AC101 codec data sheet and bodge in some functionality to do that.
http://www.x-powers.com/en.php/Info/down/id/96
I'd would code this up - but I no longer have my A1S boards for a short while
Seeed has some example AC101 code - maybe it'll help you roll some code?
https://github.com/respeaker/seeed-voic ... er/ac101.c
Adrian,
Did you ever get a solution to make LINEIN work? I'm looking for a similar solution.
Best,
Rob
Best,
Rob
Adrian,
I took a look at the code, and figured out how to make it work - so the short answer is you need to modify the ac101 codec init function - the HAL doesn't expose the necessary interfaces to control the register writing for the source selection - I downloaded the data sheet for the AC101 Codec and found the values for register 0x51 and 0x54 - here's the mods that I made:
i conditionally compiled it
in components/audio_hal/driver/ac101/ac101.c in ac101_init(audio_hal_codec_config_t *codec_cfg) modify the two register writes...
Hope that helps!
Rob
#ifndef USE_LINEIN
res |= ac101_write_reg(ADC_SRC, 0x2020);
#else
ESP_LOGI(TAG, "[ ROB ] ADC_SRC linein L/R");
res |= ac101_write_reg(ADC_SRC, 0x0810);
#endif
#ifndef USE_LINEIN
res |= ac101_write_reg(OMIXER_SR, 0x0081);
#else
ESP_LOGI(TAG, "[ ROB ] OMIXER_SR linein L/R");
res |= ac101_write_reg(OMIXER_SR, 0x0810);
#endif
Rob
Users browsing this forum: No registered users and 56 guests
