trying to wake up my esp32 (ttgo t-call) from deep sleep with the esp_sleep_enable_ext1_wakeup function. But my RTC ds3231 alarm pulls low on alarm event. that's with the ext1 methode a problem for me, because I want to use as a second possibility to wake up by push button. the ext1 function can be configured for any_high or all_low. neighther fits in my case. Would need a any_low....
Someone got a hint for me? Maybe inverting the RTC alarm signal? Or using another methode for waking up?
Thanks a lot
Markus
RTC Alarm triggering low and esp_sleep_enable_ext1_wakeup
Re: RTC Alarm triggering low and esp_sleep_enable_ext1_wakeup
Datasheet says it's an open drain output so just connect the button and the RTC interrupt to the same pin, with a single pull-up resistor.
Hi boarchuz,
thanks for your answer. True it's possible but then its more "work" to find out what triggert the wake up. At a German Forum I got a simple hint:
By that, weather IO27 or IO26 kan wake up triggering low (or high with according settings).
Thanks a lot anyway.
Markus
//Button (GPIO 26) auf Low (0)
esp_sleep_enable_ext0_wakeup(GPIO_NUM_26,0);
//Button (GPIO MASK = 2^27 = 0x800 0000 -> GPIO 27) auf Low (0)
esp_sleep_enable_ext1_wakeup(0x8000000,ESP_EXT1_WAKEUP_ALL_LOW);
Markus
Users browsing this forum: No registered users and 49 guests
